Can I reduce or disable built-in IR LED glare on Arducam 1080P USB camera?
Hi everyone. I’m setting up an Arducam 1080P Day/Night Vision USB Camera (SKU: B0506) in the lab and ran into an issue. When I point it at a very reflective surface, the built-in IR LEDs create really intense glare, like the whole image gets blown out. Does anyone know if the brightness of the IR LEDs can be turned down at all?
Welcome to the forum! That glare sounds pretty bad. Could you share a bit more about your setup? What software are you capturing with, and what kind of surface/environment is the camera aimed at? It’ll help figure out whether there’s any LED control available on this model.
Sure. We’re using Bonsai for animal behavior recording in the lab. The camera is aimed fairly directly at a reflective surface for some new experiments we’re running. I haven’t found any brightness control in the software or on the camera itself. So I have two questions really: can the onboard IR LED intensity be reduced, and alternatively, could we use a dimmer external IR lamp and switch off the camera’s own LEDs?
Thanks for the details. I checked the specs for the B0506. Unfortunately the IR LEDs on this camera are driven at a fixed intensity. There’s no adjustable current or pulse-width control exposed through UVC or the camera firmware, so there’s no brightness slider or setting that will change them.
Okay, that’s what I was afraid of. What about the second part? Is there any way to disable the onboard LEDs entirely, maybe through a jumper, a firmware flag, or some hidden setting? Then we could just run a separate dimmable IR illuminator.
I looked into that as well. On this SKU the IR LEDs are tied to the day/night switching and can’t be independently disabled. There’s no firmware flag, no exposed register, and no physical switch on the board for the LED circuit. So unfortunately that route isn’t available either.
Hmm, that’s frustrating for our use case. Just to be completely sure — there’s no workaround in Bonsai or through the camera’s UVC controls to at least dim them? I was hoping something in the exposure settings might help.
Bonsai’s exposure controls affect overall image brightness, but they don’t reduce the actual IR illumination hitting the reflective surface, so the glare from the LEDs themselves remains. To sum up: the IR LED intensity on the Arducam 1080P Day/Night Vision USB Camera (SKU: B0506) is fixed and cannot be adjusted, and there is no way to disable the LEDs on the camera.
