Camera timeout error with dual IMX708 Arducam cameras on Raspberry Pi 4B
That worked — the adapter is now giving me a feed from both cameras. Thanks!
One remaining issue: occasionally the cameras have a sudden flash in the feed. It can last from just a couple of frames up to 5-7 seconds. Is that expected, or is it likely a poor ribbon cable connection? I attached a short video of it happening.
Good to hear it’s working. The flashing/flicker sounds like unstable data transmission, which is usually a poor MIPI/ribbon cable connection. Can you post photos of the hardware connection? If you have any spare MIPI cables, swap them in and test again to see if the flicker goes away.
Quick question about the OS. I’m considering changing over to Ubuntu MATE. It doesn’t have libcamera, but V4L2 is available. Would that change the setup much, or cause any big problems with this adapter?
The multi-camera adapter isn’t supported on Raspberry Pi Ubuntu OS. Arducam doesn’t release a driver for it there, so it won’t work on Ubuntu MATE even with V4L2.
