Hi everyone, I’m having trouble with my Arducam IMX283 USB 3.0 camera. The camera port keeps disconnecting during operation, and I can’t reliably read frames from it. It will work for a bit and then just drop out. I’m happy to share my OS and version, camera model and firmware version, and any logs or error messages I’m seeing if that helps narrow things down.
Thanks for the report. To help figure out the root cause, can you share the following: full OS details and version, the camera model number and current firmware version, and any error messages you’re seeing in the system logs? Also, please double-check a few physical things: is the USB cable securely connected at both ends, are you using the original USB cable that came with the camera, have you tested it in different USB ports, and is the camera mounted without physical stress on the USB connection? A short video showing the disconnection when it happens would also be really useful.
Just to update: I already installed the UVC firmware earlier following prior guidance, but the exact same problems are still there. Environment details: Ubuntu 22.04.5 LTS, Arducam IMX283 USB 3.0. I’ve confirmed the USB cable is securely connected at both ends, I’m using the original cable that came with the camera, I’ve tested it in different USB ports, and the camera is mounted with no physical stress on the USB connection. I’ll share a video of the disconnection and the system logs containing the camera-related error messages. Separately, could you give me the detailed steps to install the ISO firmware on the Arducam?
Thanks for confirming those checks. Since the UVC firmware didn’t resolve the disconnections, let’s move on to the ISO firmware. I’ve sent you the guide video through private message — the ISO firmware installation steps are in the second half of the video. Please check your messages and follow that portion carefully.
I watched the video and opened the firmware tool, but the .exe only shows UVC and FPGA options — there’s no ISO option at all.
Can you provide the .exe that actually includes the ISO firmware installation option?
That’s strange — the flashing tool should offer ISO, UVC, and FPGA options, but from your screenshot the .exe you have is missing the ISO option entirely. It looks like you’ve been given an incomplete tool version. I’ve sent you a reference link through private message for the correct tool. Please check your messages and use that one instead.
Got it, thank you. I’ll proceed with updating the ISO firmware using that tool and will report back if anything is still misbehaving or if there are any developments.
To summarize where we are: the UVC firmware was already installed on the Arducam IMX283 USB 3.0 (Ubuntu 22.04.5 LTS), but the disconnections and frame-read issues persisted even after all the USB connection checks passed. The current path is to install the ISO firmware — the first tool you had was missing the ISO option, so I’ve provided the correct tool. Please go ahead with the ISO update and let us know if the disconnection issue continues after that.
