Camera not working on RPi Zero with MIPI drivers
EDIT: Fixed post formatting
robotshop.com/de/de
https://www.arducam.com/product/arducam-high-quality-camera-for-jetson-nano-and-xavier-nx-12mp-m12-mount/
Raspberry Pi Zero W
https://github.com/ArduCAM/MIPI_Camera for RPI
Never worked
Hi all,
I’m struggling with this camera on the raspberry pi Zero W (rev. 1.1), Raspberry Pi OS buster: https://www.robotshop.com/de/de/arducam-mini-hq-123mp-imx477-kamera-mit-m12-objektiv-jetson-nano-xavier.html
Is it even compatible with the RasPi Zero?
I followed the instructions here: https://github.com/ArduCAM/MIPI_Camera/tree/master/RPI
when I execute vcgencmd get_camera, I get
supported=1 detected=1
when I execute ./arducamstill -t 0, I get:
Open camera…
sh: 1: i2cdetect: not found
Found sensor imx477 at address 1A
mode: 0, width: 4056, height: 3040, pixelformat: BA81, desc: (null)
mode: 1, width: 8112, height: 3040, pixelformat: BA81, desc: This mode is used for stereo hat.
Get ctrl V4L2_CID_FOCUS_ABSOLUTE fail.
index: 0, CID: 0x009A090A, desc: V4L2_CID_FOCUS_ABSOLUTE, min: 0, max: 1023, default: 190, current: 0
Can’t open the file
usrvcsm: [vcsm_malloc_cache]: [1065] [mmal_vc_port buffer]: ioctl mem-alloc FAILED [-1] (hdl: 0)
usrvcsm: [vcsm_vc_hdl_from_hdl]: [1065]: invalid device or handle!
usrvcsm: [vcsm_lock]: [1065]: invalid device or invalid handle!
mmal: manually_port_pool_create: could not allocate 18531840 bytes of shared memory (handle 0)
mmal: Failed to create isp output pool.
mmal: manually_port_pool_create: could not allocate 12354560 bytes of shared memory (handle 0)
mmal: mmal_port_pool_destroy: port 0x1f947e0, pool 0x1fa1e60 destroyed while port enabled
mmal: Failed to create connection.
mmal: Failed to create pool
mmal: Failed to enable camera
Failed to set focus, the camera may not support this control.
Failed to set exposure, the camera may not support this control.
Start preview…
start preview status = 1
Am I doing something wrong? Do I have to take some additional steps?
