Hey everyone, hoping someone here has run into this. I’m setting up the Arducam U6248 with the 10 Meter Cable Extension Kit on a Raspberry Pi 5. I’ve got a consistent test bench going — same Pi, same Tx board, same power setup — I’m literally only swapping out the UC-892 Rx boards one at a time to narrow things down.
The problem: most of my Rx boards aren’t detected by the Pi at all. Like, i2cdetect -y 1 shows nothing, no /dev/video0, and dmesg doesn’t mention anything arducam-related when I plug them in. The power LED on the Rx board lights up, but the link/status LED never comes on.
Weirdly, I do have ONE Rx board that gets detected fine — /dev/video0 shows up, dmesg looks normal — but when I try to capture anything it’s just solid black frames. No image at all.
Anyone seen behavior like this with the extension kit? Is there something dumb I might be missing on the Pi 5 side?
That does sound odd, especially since you’re isolating the Rx boards as the only variable. A few things to rule out first:
Can you share the full dmesg output right after hot-plugging one of the non-detected Rx boards? Sometimes there are clues buried in the USB enumeration that don’t explicitly mention “arducam.”
You mentioned the power LED comes on — are you powering the Rx board via the USB-C port on the receiver side with a proper 5V supply? The extension kit Rx boards need external power; they won’t run off the Pi’s CSI connection alone.
What does v4l2-ctl --list-devices return when the “sort-of-working” board is connected?
Yep, external USB-C power on all the Rx boards, confirmed with a USB power meter — they’re drawing current. Power LED is solid on all of them, but the link/status LED stays dark on the bad ones.
Here’s dmesg after plugging in one of the non-detected boards:
[ 204.123] usb 1-1: new high-speed USB device number 7 using xhci-hcd
[ 204.272] usb 1-1: New USB device found, idVendor=0bda, idProduct=5411
[ 204.273] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
And that’s it. Nothing camera-related follows. No arducam, no u6248, no video device registered.
With the one board that partially works, v4l2-ctl --list-devices shows:
But capturing with v4l2-ctl --stream-mmap --stream-count=1 --stream-to=test.raw just produces a file full of zeroed-out frames. Every single frame is black.
I’ve now gone through my entire inventory — I’m counting about 18 Rx boards with this problem across multiple batches, all tested against the same known-good Tx board and cables.
18 boards is a lot to have the same failure mode. Before we call these defective, I want to rule out one more thing — the extension kit cable itself.
Can you try connecting one of the problematic UC-892 Rec boards using a regular, off-the-shelf Ethernet cable instead of the extension kit cable? I want to see if the Rx boards get detected at all when the extension kit is taken out of the equation entirely. If they suddenly work, we know the issue is in the cable run. If not, we’ve narrowed it to the Rx boards themselves.
Just ran that test. Grabbed a standard CAT5e patch cable and tried it with a couple of the bad Rx boards. No change — still not detected by the Pi at all. dmesg shows the same USB hub enumeration and then nothing.
Also tried the one board that was “detected but producing black frames” — same behavior with the standard cable. It shows up as /dev/video0 but still outputs nothing but black.
So it doesn’t look like the extension kit cable is the culprit here. The behavior follows the individual Rx boards regardless of which cable I use.
Alright, so here’s where we’ve landed after all the testing:
Same Pi 5, same Tx board, same power delivery across all tests — the only variable is the UC-892 Rec board
External USB-C power confirmed on all Rx boards (power LED on, current draw verified)
Standard Ethernet cable produces identical results to the extension kit cable — so the extension kit isn’t the issue
One board gets enumerated and registers /dev/video0 but outputs only black frames
The other ~17 boards don’t enumerate at all — no arducam device appears in dmesg, i2c, or v4l2
At this point it’s pretty clear the problem is with the UC-892 Rec boards themselves. The fact that one partially initializes (detected but no image data) while the rest fail entirely during enumeration suggests a hardware-level fault in these particular units — possibly something on the USB bridge side of the Rx board.
Unfortunately there’s not much left to try on the software or cabling front. This looks like a manufacturing defect in that batch of Rx boards.
