Hi everyone. I’ve got an Arducam Multi Camera Adapter Module V2.2 connected to a Raspberry Pi 4B and it never worked properly out of the box. The Pi just doesn’t detect the camera when it’s going through the adapter board. If I try to open the camera there’s no file that corresponds to a camera at all (no /dev/video node or similar), so every camera tool fails immediately. I was following the quick start guide in the Arducam docs (Quick Start Guide for Multi-Camera Adapter Board - Arducam Wiki) but it still doesn’t show up.
Thanks for the details. Could you post a couple of photos of the hardware connection — one at the Raspberry Pi end and one at the camera end of the adapter — and also run our bug report tool so we can see what the Pi is actually seeing? Here’s how to generate it:
- Reboot your device.
- Download the tool:
- Make it executable:
- Run it:
It creates an arducam-bug-report.txt in the current directory. Please attach that file here (or send it to me in a PM if that’s easier).
I tried running the bug report tool but it errors out before it finishes. I’ve attached a screenshot of the error message and a photo of the hardware connection. Is there another way to generate the bug report?
Thanks for the photo and the error screenshot. While I look at those, can you also run this and paste the output here:
cat /boot/config.txt
And could you tell me the exact camera modules you have plugged into the multiplexer (for example OV5647, IMX219, IMX477, IMX708)?
Sure. Platform is a Raspberry Pi 4B. On the multiplexer I have one OV5647 and one IMX219.
Here’s my /boot/config.txt:
camera_auto_detect=0
dtoverlay=vc4-kms-v3d
max_framebuffers=2
arm_64bit=1
gpu_mem=256
enable_uart=1
dtoverlay=w1-gpio
start_x=1
#dtoverlay=ov5647
dtoverlay=camera-mux-4port,cam0-ov5647,cam3-imx219
Got it, thanks. I can see the camera-mux-4port overlay is present and the standalone ov5647 overlay is commented out — I’m reviewing whether that matches your OV5647 + IMX219 combination. The bug report would still help a lot since the tool didn’t complete on your end, so I’m also checking the error screenshot you posted to figure out why it failed.
Any update on this? Just checking in.
Still investigating, no fix yet. To recap where we’re at: the camera isn’t being detected through the adapter, and the main thread I’m following right now is the device tree / camera config in /boot/config.txt for the multi-camera adapter board. I have your hardware photos, the config output, and the camera module details (OV5647 + IMX219). What’s still missing is a completed arducam-bug-report.txt — the tool errored out on your Pi, so I’m also looking at the error screenshot you posted to see why it failed. Once we get a full bug report we can see the actual kernel/camera state and figure out the next step. I’ll update the thread as soon as I have more.
