Dear Arducam Forum,
i´am using Arducam Camera Module(OV9281, Ov2311) on RPI4/8Gb. I do want to make some images in a row. I wrote a Python function to do so. When I start the function it sometimes works. But not all the time. When I take 10 images the first two are not working. The next some Images are saved in the Folder and in the end it breaks of before taking all Images. I am facing some errors:
mmal Failed to fix lens shading, use the default mode
mmal Enable JPEG encoder
mmal Failed to set cfg
mmal Failed to set rc cfg
mmal Failed to setup components
Allocate memory error
Backend terminated or disconnected. Use Stop/Restart to restart
How to fix these errors?
I don´t know why it works sometimes well and sometimes it occurs an error by calling the same function.
I would like to use .png format to save the files
I do vary the shutter speed earlier in the program. The name will get in index: file_1, file_2 and so on.
My Function: (basically the example code from Arducam)
def OV9281TakeImage(name, shutterspeed):
time.sleep(2)
if name == “main”:
try:
time.sleep(2)
camera = arducam.mipi_camera()
camera.init_camera()
##print(“Setting the resolution…”)
time.sleep(2)
fmt = camera.set_resolution(1280, 800)
#print(“Current resolution is {}”.format(fmt))
time.sleep(2)
camera.manual_set_awb_compensation(1,1)
time.sleep(2)
#print(“Setting the exposure…” + str(shutterspeed))
camera.set_control(v4l2.V4L2_CID_EXPOSURE, shutterspeed)
time.sleep(2)
#frame = camera.set_raw_callback()#encoding = ‘jpeg’
#frame = camera.capture(encoding = ‘raw’)
frame = camera.capture(encoding = ‘jpeg’)
time.sleep(2)
frame.as_array.tofile(“images//”+ str(name) + “.png”.format(fmt[0],fmt[1]))
time.sleep(2)
del frame # Release memory
#print(“Close camera…”)
camera.close_camera()
except Exception as e:
print(e)
Any help is appreciated. Thank you very much.
