Camera auto gain and manual gain control stopped working
Hi, I’m testing an Arducam UVC USB3 Sony STARVIS 2 IMX585 8MP Ultra Low Light module (model B0498). Straight out of the box it only shows 4K. Whenever I try 1920x1080 or 1280x720 in PotPlayer or similar software I get either a green screen or a black screen. Has anyone else seen this? Is there a firmware update or tool to enable the other resolutions/frame rates?
Hi there. The standard B0498 IMX585 UVC3 camera does support 3840x2160@15fps, 1920x1080@60fps, and 1280x720@90fps. If you’re only seeing 4K, that sounds like the sample firmware only exposes that combination. Any other resolution/frame-rate combination outside of those three would need extra customization and would involve an NRE fee.
Thanks for confirming. Right now I’m only getting 3840x2160@15, not the 1080p60 or 720p90. I’m deciding between this IMX585 and an IMX678 for a material inspection project, so getting the lower res / higher fps modes working matters a lot. What do I need to do to make the current module show 1920 and 1280?
Got it. If the firmware only advertises 4K, then trying 1920 or 1280 would fail with the green/black screen you’re seeing. The fix is a firmware update on the camera module. I’ve cc’d our engineer to look into it - can you fill in the technical form so they have your setup details?
Sure, I’ve filled in the form and sent it. Just let me know what to do next.
Thanks for the details. I’ve sent you the firmware update guide via private message - please check it and follow the steps in the video to update the camera module. The lower resolutions should be available after the update.
Update: the new firmware worked. I can now select 1920x1080@60 and 1280x720@90 without the green/black screen. But now I’ve hit a different issue - auto gain doesn’t seem to work, and manually changing gain also does nothing. Gain looks like it stopped working after the update.
Good to hear the resolution issue is fixed. For the gain: this camera doesn’t have a separate auto gain switch. Gain is handled by the integrated auto exposure algorithm, which manages exposure and gain together for best image quality. To adjust gain manually, you need to disable auto exposure first - then you’ll have full control over the gain values.
Ah, that makes sense. I’ll try disabling auto exposure and see if the gain values respond. Thanks for the help.
To sum it up: the original green/black screen at 1920/1280 was resolved by updating the camera firmware, and the module now exposes 3840x2160@15, 1920x1080@60, and 1280x720@90. For gain control, remember there’s no separate auto gain switch - disable auto exposure first to get manual gain control. If gain still doesn’t respond after that, let us know and we can dig further.
