I have just got a Raspberry Pi 4 B and can’t get it to work. The camera gets detected and all, but when taking a photo or use any libcamera-app it does nothing.
This is the last thing libcamera prints then nothing happens until I ctrl+c out of the terminal.
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
#camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
dtoverlay=arducam_64mp
dtparam=i2c_vc=on
dtparam=i2c_arm=on
#dtoverlay=arducam
