So in my current project work, I want to replace Rpi with a Qualcomm QCS610 chip and use the rest of things as it is like arducam HAT module.
But i am not able to capture camera image on QCS610. So i check that the configuration used in QCS610 is not correct.
So to make the correct configuration, i need the information that how RPI configure with ARDUCAM.
So can you help me for how two camera hat modules communicate with two cameras means all camera configuration is in the Arducam HAT chip itself or all camera configuration is in the Rpi module?
But I already refer to this link. The block diagram is for IMX477 and the rest of the things is the overall information relative to the setup of RPi with Arducam.
I need some information that the camera configuration is where like it’s is in RPi or it’s in Arducam HAR module’s Chip.
Because when i start the application into QCS610 i am not see the Slave id of the camera.
So please help me on this that where is the camera configuration in Rpi or in the Aducam hat module.
Thanks for this library suggestion. We tested picamera2 lib and it’s working well on RPi 4.
Now we have an interface the Arducam 12MP stereo camera HAT to QCS610.
Here we identified two slaves where the one salve id is 0x24 used for changing cameras like CAM0 or CAM1 or BOTH and the second slave id is 0x1A used for the IMX477 camera.
Also, we are able to read the chip id of the camera from the Arducam HAT module through the I2C interface of QCS610.
So I have two queries on this like;
We have interface of two IMX477 cameras with QCS610 through the Arducam HAT module then why do we get only one camera detection of 0x1A only whereas we have to interface two cameras?
As we know that the IMX477 camera Slave id is 0x34 then why do we get 0x1A slave id?
The role of HAT is to connect multiple cameras to solve the problem that the Raspberry Pi has only one cis interface. It tricks the Raspberry Pi as if there is only one camera connected.
0x1A is the address where the IMX477 camera is mounted under i2c. You can see it in the device tree of the Raspberry Pi.
When we connect Arducam HAT with our platform, we can see three slave ID as follow:
0x24
0x1A
0xC
We wrote 4 lanes IMX477 configuration on slave ID 0x1A and configure MIPI Rx to receive over 2 lanes as HAT will stream the data over 2 MiPi Lanes but we are not getting any data over MiPi. Are we missing any part here or doing something wrong?
Do we need to enable something on HAT to get data streaming ?
IMX477 configurations works fine on b0167b12 Arducam module and we get continuous stream of data on our platform.
Please do let me know if you need more information.
We did used 2 lanes configuration and wrote those configurations on 0x1A slave ID but still we are not getting any MIPI data. If we read chip ID we can successfully able to read it (0x477). What could be the issue ? What are your suggestions for further debugging ?
