Burning 16MP camera firmware shows Sonix Camera Co., LTD instead of Arducam imx298 AF
Trying to sort out IMX298 firmware export/burning and hit something odd that I figured I’d share since it’s now working on my end.
Environment:
  • Arducam imx298 AF Camera (source of the firmware)
  • 16MP Camera (target being flashed)
  • USB_XU_BurnerAP.exe for export
  • CommonBurnerAP v1.0.1.8.exe for burning
  • Firmware files: SonixAllRomFile.src, SonixAllRomFile1.src
What I did:
  1. Exported firmware from the Arducam imx298 AF Camera using USB_XU_BurnerAP.exe, which produced SonixAllRomFile.src.
  2. Flashed the 16MP Camera using CommonBurnerAP v1.0.1.8.exe.
The weird part:
  • Uploading SonixAllRomFile.src as-is → the camera enumerates as “Sonix Camera Co., LTD” (undesired)
  • Renaming SonixAllRomFile.src to SonixAllRomFile1.src → enumerates as “Arducam imx298 AF Camera” (desired)
The renaming was just my usual trick for hunting software bugs, and it happened to work here. Screenshots below:
Has anyone else seen the burner tool care about the filename like this?
Thanks for posting this - that’s a great data point. The burner tool really shouldn’t be parsing the filename, so that behavior points to a quirk/bug in CommonBurnerAP rather than anything in the firmware itself.
A couple of questions to confirm what you’re seeing:
  • Is “Sonix Camera Co., LTD” vs “Arducam imx298 AF Camera” showing up in Windows Device Manager?
  • Before you flash the new 16MP cameras, what name do they show up as?
  • Are the source and target cameras from different production batches?
Yes, all of this is in Windows Device Manager. Before flashing, the recently purchased 16MP units show up as “Arducam_16MP”. The older cameras (the ones I bought around 7/22/2022) show up as “Arducam imx298 AF Camera” out of the box.
There’s also a noticeable image quality difference: in the same test setup, the Arducam_16MP units are darker than the Arducam imx298 AF Camera units. The older batch is brighter and much better in low light. That’s the whole reason I started pulling firmware from the good batch to flash onto the new batch.
That lines up with what we’ve been seeing on our side. Different batches of these IMX298 boards shipped with different firmware, which explains:
  • the different enumeration names (“Arducam imx298 AF Camera” vs “Arducam_16MP”)
  • the different image quality/performance between the two batches
Your plan is correct: extract from the older batch and burn that firmware onto the recently purchased cameras, then compare performance. Since the rename trick flipped the enumeration to the right name, keep using SonixAllRomFile1.src.
Two more things:
  • I’ve sent you a guide video via private message that walks through exporting firmware from the older cameras and burning it onto the newer ones. Please check your messages.
  • As an alternative test, you can also try firmware UVC_B0290_20221018.bin and see if that improves things a lot.
Let us know how the flashed new batch compares to the old batch afterwards.
Got the video, thanks. Yes, I’ll check the performance of the new batch cameras against the old batch after burning the firmware and post the results. I’ll also give UVC_B0290_20221018.bin a try and see how it behaves. Give me a bit of time to run the comparisons on a few more units.
Sounds good. To summarize where we are: exporting firmware from the good (old) batch and burning it onto the new batch is the working approach. The key workaround is renaming the extracted file from SonixAllRomFile.src to SonixAllRomFile1.src - that changes enumeration from “Sonix Camera Co., LTD” to “Arducam imx298 AF Camera”. We’ll wait for your results on the performance comparison and whether it holds across multiple cameras before considering this fully closed. Keep us posted.
