Blue image on Arducam 477P Jetson camera – is protective film still on?
Hi everyone, I’m having trouble with my Arducam for Jetson 12.3MP 477P HQ Camera Board (B0279) on an Nvidia Jetson platform. The captured image has a strong blue tint — everything looks washed out in blue. This is a fresh setup and it’s never worked correctly since I got it.
One thing I noticed — is there supposed to be a thin blue plastic protective film on the sensor, like you see on Raspberry Pi camera modules? I tried peeling it off with some cellophane tape but nothing came off. Is it normal for the image to appear this blue? I’m starting to wonder if the sensor itself is defective.
Welcome to the forum! Before we jump to any conclusions about hardware, could you share a photo of your current hardware setup — how the camera is connected to the Jetson board? It would help rule out any connection issues first.
Sure, here’s a sample image captured from the camera so you can see what I mean:
You can see the blue cast across the entire frame. This is straight out of the camera with default settings.
Thanks for the image — that’s very helpful. I can tell you right away this is not a hardware defect and it’s not a protective film issue either. What you’re seeing is a known problem with the IMX477 camera module on Jetson platforms: the blue tint is caused by a missing or incorrect ISP (Image Signal Processor) calibration file.
By default, the Jetson ISP doesn’t have the correct calibration parameters for the IMX477 sensor, which results in the color balance being way off — hence the blue cast.
There’s a community-maintained calibration override file from RidgeRun’s repository that addresses this. Run the following commands on your Jetson:
wget https://raw.githubusercontent.com/RidgeRun/NVIDIA-Jetson-IMX477-RPIV3/master/li-camera-calibration-files/camera_overrides.isp
sudo cp camera_overrides.isp /var/nvidia/nvcam/settings/
sudo chmod 664 /var/nvidia/nvcam/settings/camera_overrides.isp
sudo chown root:root /var/nvidia/nvcam/settings/camera_overrides.isp
After that, reboot or restart your camera pipeline and the blue tint should be gone. Give it a try and let me know how it goes.
That did it! I ran all the commands, rebooted, and the blue tint is completely gone — colors look normal now. I was convinced I had a bad sensor or that I was going crazy trying to peel off a film that wasn’t there. Thanks for the quick diagnosis, really appreciate it!
Glad that sorted it out! Yeah, the missing ISP calibration file issue catches a lot of people off guard since the camera otherwise appears to work — it just produces that heavy blue cast. For anyone else stumbling on this thread with the same Arducam IMX477 + Jetson combo, the RidgeRun repo linked above is the go-to fix. Marking this as resolved. Cheers!
