Hi, I’m putting together a depth-sensing stereo camera setup on a PC using the Arducam 1080P Low Light Low Distortion USB Camera Module with Microphone. The <1% distortion spec is pretty critical for what I’m doing. When I tested the first camera, I could already see distortion toward the edges of the image just by eye. It’s not a subtle effect.
Thanks for reaching out. Could you share a couple of sample images showing the distortion you’re seeing? I took a test image this morning and it looked normal on my side, so it would help to see exactly what you’re getting. Is this happening on both cameras or just one?
I tested both cameras at the same time and they both show the same massive barrel distortion toward the edges. So it’s not just a single unit doing this.
Understood. If you can send over a few pictures of the distortion, that would be really helpful. I’d like to compare what you’re seeing against what I’m seeing here.
I did a quick measurement to try to quantify it. I placed a small ball dead center at a distance where it measured exactly 100 pixels in diameter. Then I moved it along a line perpendicular to the camera axis toward the edge of the image. At the edge, its diameter measured up to 120 pixels in some spots, which is roughly a 20% difference. For a camera advertised as <1% distortion, that seems way off. It basically makes it unusable for my stereo depth setup. I’m not sure if I got a faulty unit or if the distortion spec just isn’t accurate.
Thanks, that measurement is really useful. A ball going from 100 px in the center to around 120 px near the edge does point to significant edge distortion, and it’s hard to reconcile that with a <1% spec. For reference, here’s the image I captured this morning, which looked normal to me:
We haven’t pinned down the root cause yet. It could be a faulty unit, or the actual distortion could be exceeding what’s advertised. Please send over the pictures you captured so we can evaluate them side by side with this one.
