Hi everyone. I’m trying to get a B0492N stereo camera working on a Jetson Orin Nano Developer Kit, but the camera isn’t showing up at all. When I run ls /dev/video0 I just get:
Thanks, that’s helpful. A few things stand out in that log:
arducam_csi2 is loading as an out-of-tree module. That’s why you see no symbol version for module_layout and the “taints kernel” lines. Those are normal for out-of-tree modules and not the real issue.
That means the driver can’t read from the sensors over I2C at addresses 9-000c and 10-000c. Because the sensors never initialize correctly, the CSI device never gets registered, which is why /dev/video0 isn’t created. So this looks like a camera/I2C/CSI probe failure rather than a simple permissions or video device issue.
Ah, so the sensors aren’t even being detected on the I2C bus? What should I do next to figure out why the probe is failing? Happy to gather whatever info is needed.
Please don’t attach it publicly since it can contain system details. I’ve sent you a private message, so you can send the arducam-bug-report.txt file over there for review. To summarize where we are: the camera isn’t detected because the arducam_csi2 driver is failing to probe the sensors at I2C addresses 9-000c and 10-000c (Reading register 0x103 failed / Failed to setup board). The bug report will help us dig into that I2C/CSI probe failure and figure out the next step.
