Where did you get the camera module(s)? arducam.com
Model number of the product(s)? B0433
What hardware/platform were you working on? Linux Ubuntu
Instructions you have followed. (link/manual/etc.) I followed v4l2 on how to set exposure and capture raw image
Problems you were having? No matter what exposure_absolute value I give to the camera, the imae doesn’t change. It looks like the frame rate is what decides the exposure time.
I tried using the camera from the windows application and had no problems with changing the exposure time manually. I don’t understand if it’s a camera module problem or is v4l2 problem
Which command did you use to change exposure value?
I used this
v4l2-ctl --set-ctrl=exposure_auto=1 --set-ctrl=exposure_absolute=*any number between 3 and 2047
What I found out yesterday is that it might be just a driver issue of the camera. Because by adding the command to skip frames, the exposure changes. Or at least it seems to be working now
