Thanks — that’s the missing piece. I tested the same camera here to compare.
On my side, a Pi 4B running Raspberry Pi OS 11 (bullseye):
uname -a
Linux raspberrypi 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l GNU/Linux
cat /etc/os-release
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
On that box the camera came up fine:
dmesg | grep arducam
[ 8.752352] arducam: loading out-of-tree module taints kernel.
[ 8.773350] arducam-pivariety 10-000c: firmware version: 0x10003
[ 9.200336] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
ls /dev/video0
/dev/video0
v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Stepwise 16x16 - 16376x16376 with step 1/1
[1]: 'UYVY' (UYVY 4:2:2)
[2]: 'YVYU' (YVYU 4:2:2)
[3]: 'VYUY' (VYUY 4:2:2)
[4]: 'RGBP' (16-bit RGB 5-6-5)
[5]: 'RGBR' (16-bit RGB 5-6-5 BE)
[6]: 'RGBO' (16-bit A/XRGB 1-5-5-5)
[7]: 'RGBQ' (16-bit A/XRGB 1-5-5-5 BE)
[8]: 'RGB3' (24-bit RGB 8-8-8)
So the hardware and the driver package do work on bullseye with kernel 5.15.32. The difference is on your side the driver installs but the camera never registers with libcamera (‘No static properties available’, missing arducam-pivariety.json, and finally ‘no cameras available’), which lines up with a driver/package mismatch rather than a hardware fault.
Compare that to your dmesg, which confirms kernel 5.15.32 (Linux version 5.15.32-v7+ … Raspberry Pi 3 Model B Plus Rev 1.3) with the module loading:
[ 0.000000] Linux version 5.15.32-v7+ (dom@buildbot) … #1538 SMP Thu Mar 31 19:38:48 BST 2022
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 8.675198] i2c 10-000c: Fixing up cyclic dependency with 3f801000.csi
[ 12.327066] arducam: loading out-of-tree module taints kernel.
[ 12.342813] arducam-pivariety 10-000c: firmware version: 0x10003
[ 12.858767] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
[ 33.111192] cam-dummy-reg: disabling
The URL you used (arducam_kernel_driver_5.15.y.tar.gz) is the one that installs the driver build matching the 5.10.17 Raspberry Pi version — mismatched with your 5.15 Bullseye system. I think you installed the wrong driver package for your OS/kernel version, which is why the manual cd Release/ + ./install_driver.sh produced:
install: cannot stat ‘./bin/5.15.32-v7+/arducam.ko’: No such file or directory
install: cannot stat ‘./bin/5.15.32-v7+/arducam.dtbo’: No such file or directory
It doesn’t have a prebuilt 5.15.32-v7+ (Pi 3B+) binary in that tarball, so nothing matching your kernel gets installed.
