Hey everyone, I’m having trouble getting my Arducam B0310 IMX708 to be recognized at all. I’ve tried it on two different setups — a Raspberry Pi CM4 running OpenHD and a Raspberry Pi 5 on Raspbian — and the OS just doesn’t see the camera on either one. No /dev/video0, nothing in dmesg, it’s like it’s not even plugged in. Has anyone run into this with the IMX708 before?
Quick update on what I’ve tried so far: I double-checked that the overlay and auto-detect settings are correct in config.txt, tried multiple Pi boards, and even tested with different camera libraries (libcamera, raspistill, etc.). Same result across the board — camera is completely undetected. At this point I’m thinking the unit might have been dead on arrival. Is there anything else I should try before looking into a return?
Sorry to hear you’re having trouble with the IMX708. Before we jump to any conclusions about a hardware fault, could you help me out with some diagnostic info? It would really help to see how everything is physically connected. Could you post a couple of clear photos showing the camera connection at both ends — the Pi side and the camera module side? Also, I’d like to get a system bug report from you to check the software side of things. I’ll post the steps for that next.
Here’s how to generate the bug report — it’ll give us a good snapshot of what’s going on under the hood:
First, reboot your Pi so we’re starting from a clean state.
Download the bug report tool:
- Make it executable:
- Run it:
This will spit out an arducam-bug-report.txt file in your current directory. If you can attach that along with the connection photos, I’ll be able to get a much clearer picture of whether this is a hardware or configuration issue.
Thanks for the instructions. Just a heads up though — I actually already sent connection photos and a bug report to another person from Arducam support via email a little while ago. I was going back and forth with them before posting here. Is there a way for you guys to check internally so I’m not duplicating everything? If not I can re-run the tool and re-send, just want to avoid the extra back and forth if possible.
Ah, got it — thanks for letting me know. Let me look into that on our side. In the meantime, if you still have the arducam-bug-report.txt file handy, it wouldn’t hurt to attach it here as well so I can start reviewing it while I track down the other ticket. Same goes for the connection photos if you’ve got them. The diagnostic data is really the key here — once we can look at the bug report and the physical setup, we’ll be able to tell whether this is a software/config misstep or an actual hardware fault with the camera module. I’ll hold off on any replacement discussion until we’ve had a chance to analyze that data properly.
