B0273 camera cable doesn't fit Jetson Orin Nano and imx477 driver install fails
Hi everyone, I recently picked up a B0273 Camera Module hoping to use it with my Jetson Orin Nano Developer Kit, but I’m stuck at the very first step. The module only came with a 22p to 15p cable, and the Orin Nano dev kit has a 0.5mm 22p CIS camera connector. So the included cable doesn’t actually fit the board at all. Can anyone tell me what adapter board or cable spec I need, and where I can get it?
Thanks for posting the details. The B0273 is normally shipped with a 22p to 15p cable for the standard Raspberry Pi-style connector, but the Orin Nano Developer Kit’s CIS connector is a 0.5mm pitch 22p connector. For that board you need a 22-to-22 pin cable, not the 22p to 15p one that came in the box. If you have a 22p to 22p cable that’s 0.5mm pitch on both ends, that should connect the camera directly to the dev kit. Let us know once you have the cable and we can move on to the driver setup.
Okay, that makes sense. I managed to get hold of a 22p cable and the camera is now physically connected. Now I’m trying to get the driver installed. My environment is: Jetson type: NVIDIA Orin Nano Developer Kit, kernel version: 5.10.104-tegra-35.3.1-20230319081403. What should I run to install the imx477 driver?
For the imx477 driver, you’ll want to run the install script with the imx477 module flag. Please run exactly this command: $ ./install_full.sh -m imx477 and paste back whatever output you get. The script checks your kernel and Jetson type and then tries to pull the matching deb package, so the output will tell us a lot.
I ran it as you said: $ ./install_full.sh -m imx477. It failed with this output: ‘Cannot find the corresponding deb package, please send the following information to [email protected]’. It also listed: Kernel version: 5.10.104-tegra-35.3.1-20230319081403, Jetson type: NVIDIA Orin Nano Developer Kit. So the installer just exits without doing anything. Any idea why it can’t find the package?
That specific error means the installer couldn’t find a prebuilt deb package matching your kernel version and Jetson type. It’s the script’s way of saying there isn’t a compatible package available for your exact combination. If you haven’t already, please send those two lines (kernel version and Jetson type) to [email protected] so it’s logged against the right platform. Meanwhile, can you confirm your kernel is 5.10.104-tegra-35.3.1-20230319081403 and the board is the NVIDIA Orin Nano Developer Kit?
Yes, confirmed. Kernel version is 5.10.104-tegra-35.3.1-20230319081403 and the board is the NVIDIA Orin Nano Developer Kit. I’ve sent the info to the support address as the error asked. Is there something wrong with my setup, or is this platform just not supported yet?
Good, that matches what we’d expect. To be upfront: the Orin Nano platform isn’t currently supported by our camera driver packages, which is why the installer reports ‘Cannot find the corresponding deb package’. There is no matching deb package for the NVIDIA Orin Nano Developer Kit on kernel 5.10.104-tegra-35.3.1-20230319081403 yet. Our team is actively working on the Orin Nano camera driver, and the expected release is within the next two months. In the meantime, the key points are: (1) the B0273 needs a 22-to-22 pin cable for the Orin Nano’s 0.5mm 22p CIS connector, and (2) driver support for Orin Nano isn’t available yet. Please stay tuned for the upcoming driver release rather than trying to force the current installer.
