Amazon
B0268
Raspberry Pi 4
Never Worked
I recently purchased a B0268 (16MP USB Camera) to use with my Raspberry Pi.
I’m using a very basic OpenCV script and I am able to change the default resolution of the camera.
import cv2
w=3840
h=2160
camera=cv2.VideoCapture(1) #confirmed this is the correct camera
camera.set(3,w)
camera.set(3,h)
ret,frame=camera.read()
cv2.imwrite("CV2_Image.jpg,frame)
camera.release()
This produces a 1024x768 image regardless of what w an h are set to
Ive tried different cameras to see if I was able to change their resolution and I was able to
Please provide corrective steps to identify how to control resolution within cv2
Thank you - I continued playing with things and realized that I was only able to change the resolution to larger resolutions with MJPG formatting. Once I set that in OpenCV I was able to change the resolution.
I have noticed that the camera is performing very poor in low light conditions and it appears that it will not budge from 30FPS. Will autoexposure not allow the camera to reduce FPS in order to achieve a better image?
Yes, when the light is low, the exposure time will be increased to reduce the frame rate. In order to prevent the frame rate from being too low in low light conditions, the firmware has made some restrictions.
