B0267 camera blank window with libcamera-still on Pi 4 Bullseye, dmesg 0x107 failed
Hi, hoping someone can help. I just got the B0267 (1MP*4 Quadrascopic OV9281 Global Shutter Monochrome Camera Bundle Kit for Raspberry Pi) and I can’t get it working at all on Bullseye. If I run libcamera-still or libcamera-hello I only get a blank window, nothing ever shows up. And dmesg is spitting out “reading register 0x107 failed”. Tried a bunch of reboots already. Is this something obvious I’m missing?
Hey, welcome. Sorry you’re hitting this. Can you share your full setup so we can narrow it down? Specifically:
  • Exact product/SKU
  • Which Pi board and how much RAM
  • OS version and kernel (uname -a)
  • Whether you’ve followed any of our camera tutorials yet
Also, paste the output of dmesg | grep arducam so we can see what the driver is reporting.
Sure. Here’s everything:
  • Product: SKU B0267, 1MP*4 Quadrascopic OV9281 Global Shutter Monochrome Camera Bundle Kit for Raspberry Pi
  • Platform: Raspberry Pi 4 Model B, 8GB RAM
  • OS: Bullseye 64-bit, Kernel 5.15
One thing I noticed: if I swap the SD card for one running Buster (older drivers), the camera actually works. So it seems specific to Bullseye.
I did follow your tutorial here:
https://www.arducam.com/docs/cameras-for-raspberry-pi/synchronized-stereo-camera-hat/camarray-arducam-1mp-monochrome-quadrascopic-camera-bundle-kit-2/
Thanks, that’s a useful detail — the Buster vs Bullseye difference is a big clue.
Can you do two things for me?
  1. Run dmesg | grep arducam on boot (no camera app running) and post it.
  2. Then launch libcamera-hello, and WHILE that window is still open, run dmesg | grep arducam again and post that too.
I want to see what changes once the app tries to actually stream.
Ok, here’s the first one right after boot:
[    3.482911] arducam: loading out-of-tree module taints kernel.
[    3.487203] arducam: module verification failed
[    3.521004] arducam: firmware version: 0x00010203
So it does detect the camera and shows a firmware version. Let me grab the second one.
And here’s the second run, with the libcamera window open:
[   77.652188] arducam: reading register 0x107 failed
[   77.653412] arducam: reading register 0x107 failed
So the 0x107 error only appears once the app tries to open the camera. Both libcamera-still and libcamera-hello just show a blank window and never produce an image.
Perfect, that confirms it. The driver loads and reads the firmware fine, but it fails talking to the sensor registers once streaming starts — which is why you get the blank window. Can you confirm the Buster test once more, e.g. same camera + ribbon on a Buster SD card with the older drivers, and it streams normally?
Yes, confirmed. Same hardware, only swap the SD card for Buster and it works fine with the older drivers. On Bullseye I just get the blank window and the 0x107 failure.
For reference this is the product page I’m working from:
https://www.arducam.com/product/arducam-1mp4-quadrascopic-camera-bundle-kit-for-raspberry-pi-nvidia-jetson-nano-xavier-nx-four-ov9281-global-shutter-monochrome-camera-modules-and-camarray-camera-hat/
Got it, thanks. Let me explain what’s happening.
The B0267 was originally designed for the Buster system using the Arducam OBISP driver, so it can’t be used on Bullseye with the current firmware/driver. The older camera version adopts a different device tree than the newer units, so a plain libcamera setup won’t work — the Python/OpenCV script has to be written to match that older device tree. We stock units in the warehouse that already have updated firmware, and the script I’ve been compiling was built for the new firmware, so I’m adapting the OpenCV script for the old-version device tree for you.
Also worth knowing: the B0267 output is 1x4 horizontally stitched, because the program is written to the hardware original — it can only do 1*4 output. 2x2 square output isn’t supported for this version.
I’ve sent the adapted Python script to you through private message. Please download it locally and give it a try.
Got the script from private message, thanks. Quick question on running it — do I need anything extra installed first, or just run the file?
Just install OpenCV first, then run the script. Steps:
  1. Install libopencv:
sudo apt install libopencv-dev
  1. Make sure the script from the private message is saved locally (test.py).
  2. Run the camera:
python3 test.py
Note: inside the program, press “s” to save a frame.png file and exit the program, and press “q” to exit.
Ok, I’ll try it out by mid-week and report back whether it works.
Reporting back — I ran the script and it works! Installed libopencv-dev, ran python3 test.py, and I’m getting a proper image now instead of the blank window. Pressing s saved frame.png and exited cleanly. Thanks for the adapted script.
Great, glad it’s working for you now. To wrap up for anyone else reading:
Root cause — the B0267 was originally built for Buster using the Arducam OBISP driver and can’t run on Bullseye with the current firmware/driver. The older version uses a different device tree, so the Python OpenCV script needs to be written to match it. That’s why libcamera gave a blank window and dmesg showed “reading register 0x107 failed”.
Working setup:
  • OS: Bullseye 64-bit, Kernel 5.15 (also worked on Buster with the older drivers)
Steps that worked:
  1. sudo apt install libopencv-dev
  2. Save the provided script locally
  3. python3 test.py (press “s” to save frame.png and exit, press “q” to exit)
Setup guide for reference:
One thing to keep in mind: output for this camera is limited to 1*4 horizontal stitching since that’s how the hardware original is written. For Bullseye support, a new camera version is planned. If you need customization specifically for Bullseye usage on an older Buster-designed B0267, reach out to [email protected].
