Having a strange problem with two Arducam B0262 cameras I’ve got here. One is revision E2 and works flawlessly — plug it in and it’s detected right away, image looks great. The other is revision D and it’s completely dead as far as I can tell. Tried the same USB cable, same port, same computer — the Rev E2 pops up every time, the Rev D does absolutely nothing. No lights, no detection in device manager, nothing. Even swapped cables around to rule that out.
On a related note, I’m planning to order a few more B0262 cameras and I’m a bit concerned — which revision is currently shipping? I’d rather not end up with more of the Rev D boards if there’s a known issue with them.
Good question on the stock situation. Our current B0262 inventory includes a mix of Rev.C and Rev.E2 units — so it could be either depending on what gets pulled. If you specifically want the Rev.E2, you can request it by adding a note to your order and our fulfillment team will accommodate that. I’d also suggest sending a confirmation message after placing the order just to be safe.
In the meantime, let’s see if we can get that Rev.D working. Can you share a bit more about your setup so we can dig into this?
