Having a strange issue with Arducam B0251 camera modules and hoping someone here has insight. We’re using these on an Evobot research platform, connecting them to both NVIDIA Jetson Orin and Luxonis boards. Our original batch of B0251 Rev D modules worked perfectly on both setups — no issues at all. We recently reordered more B0251s and received Rev E2 versions instead. Out of the whole batch, only ONE module works. The rest are completely non-functional on the exact same hardware and software setup. Nothing changed on our end. Anyone else run into this with Rev E2?
Thanks for reaching out. That’s definitely unexpected behavior — especially since your Rev D modules worked without issue on the same setups. Let’s dig into this. Have you had a chance to physically compare the Rev D and Rev E2 boards side by side? Any visible differences in components, layout, or anything else that stands out? That might give us a clue about what changed between revisions.
Yeah, I’ve spent some time comparing them under magnification. There are definitely differences: The PCB layout is not the same — traces and component placement have been reworked between Rev D and Rev E2. Some of the Rev E2 modules have components populated on the front side of the board while others don’t, which is odd. The big one: Rev E2 has a resistor on the XVS line that isn’t present on Rev D at all. That seems like a functional change, not just a layout tweak. My guess is that resistor on XVS is causing some kind of signaling or timing issue on our boards. Could that be what’s breaking compatibility?
Good eye on the XVS line resistor — that’s a significant detail. I’ve looked into this and here’s what’s going on: The B0251 Rev E2 is an upgrade from Rev D that was developed and validated primarily against the NVIDIA Jetson Orin carrier board. The changes — including that resistor on XVS, the revised PCB layout, and component changes — were made to expand the camera’s performance envelope. The tradeoff is that these same changes narrowed backward compatibility. So your Rev D modules worked across both Jetson Orin and Luxonis boards, but Rev E2 is more tightly tuned. That’s why one module might still work (likely just barely within tolerance) while the rest don’t. It’s not a defect — it’s a compatibility gap introduced by the hardware revision.
That makes sense, but it puts us in a tough spot. We’re mid-research on this Evobot platform and planning to publish — we were going to specifically mention the Arducam B0251 modules. We can’t redesign our carrier boards around Rev E2 at this stage. Is there any way to still get Rev D modules? Or is there some modification we can make to the Rev E2 boards to restore compatibility? I’m comfortable with soldering if we know what needs to change.
Totally understand the position you’re in, especially with a publication timeline. Let me lay out what’s available: All current B0251 production inventory is Rev E — Rev D is no longer being manufactured. However, we do still have a limited quantity of Rev D modules in our remaining stock. I can arrange to send a couple of those your way so you can keep your research moving. For larger quantities though, that’s not going to scale — the remaining Rev D stock won’t cover bulk needs. The other path is: our sales team can work with you on a customized solution to get the B0251 Rev E working reliably on your current boards. That would involve going through the technical specifications of your setup and tuning accordingly. For that, you’d want to reach out to [email protected] for specs and pricing. Bottom line: B0251 Rev E2 is not a drop-in replacement for Rev D. If you’re upgrading from Rev D, you really need to verify compatibility on your specific hardware first, or go the custom route.
Got it, that’s really helpful. Let me take you up on the offer for a couple of Rev D modules from remaining stock — that’ll at least keep our current experiments running. Before I commit to anything larger, what’s the pricing on those Rev D modules? And separately, any ballpark on what a custom Rev E solution typically runs? Just trying to figure out which path makes sense for the lab budget.
