Arucam IMX462/B0444 and Rpi 5
i have connected my camera and installed everything via the quick start - includimg the modification after [all].
here is what i have for dmesg
SkyPi@SkyPi:~ $ dmesg | grep arducam
[ 0.532565] platform 1f00128000.csi: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/i2c@80000/arducam_pivariety@c
[ 2.998718] arducam-pivariety 4-000c: pivariety_read: Reading register 0x103 failed
[ 2.998726] arducam-pivariety 4-000c: probe failed
[ 3.020236] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_pivariety@c
SkyPi@SkyPi:~ $ dpkg -l | grep libcamera
ii libcamera-dev:arm64 0.3.2+rpt20240927-2 arm64 complex camera support library (development files)
ii libcamera-ipa:arm64 0.3.2+rpt20240927-2 arm64 complex camera support library (IPA modules)
ii libcamera-tools 0.3.2+rpt20240927-1 arm64 complex camera support library (tools)
ii libcamera0.3:arm64 0.3.2+rpt20240927-2 arm64 complex camera support library
ii libspa-0.2-libcamera:arm64 1.2.4-1~bpo12+1+rpt1 arm64 libraries for the PipeWire multimedia server - libcamera plugin
ii pipewire-libcamera 1.2.4-1~bpo12+1+rpt1 all transitional package for libspa-0.2-libcamera
ii python3-libcamera:arm64 0.3.2+rpt20240927-1 arm64 complex camera support library (Python bindings)
I keep getting no camera found from libcamera. please advise
kyPi@SkyPi:~ $ sudo libcamera-hello
[1:03:06.684866048] [5097] INFO Camera camera_manager.cpp:325 libcamera v0.3.2+51-28bff115-dirty (2024-10-08T05:59:20BST)
error: XDG_RUNTIME_DIR is invalid or not set in the environment.
Made X/EGL preview window
SkyPi@SkyPi:~ $
Could you post the output of the command below?
cat /boot/firmware/config.txt
Besides, it would be helpful if you post the pictures of the hardware connection
Little heads up that please attach the picture in the goolg drive.
looks like it was a hardware issue. a new ribbon cable worked. however im having issues trying to sSkyPi@SkyPi:~/camera_stream $ gst-launch-1.0 v4l2src ! “video/x-raw, format=YUY2, width=320, height=240, framerate=15/1” ! videoconvert ! autovideosink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
…/sys/v4l2/gstv4l2src.c(976): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
Execution ended after 0:00:00.010994857
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Setting pipeline to NULL …
…/libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Freeing pipeline …
tart the camera with openCV.
it says online the sensor should be compatible. thanks so much
You can refer to the doc below.
https://www.raspberrypi.com/documentation/computers/camera_software.html#gstreamer
