Greetings,
Using your single board IMX298 on multiple Pi 4s, I have my own code (using libarducam_mipicamera.so) failing.
I downloaded and did a make build
and make install
on the latest download from Github.
Running ardustill returns the following output
pi@raspberrypi:~/MIPI_Camera-master-3/RPI $ ./arducamstill
Open camera...
init camera status = 4099
I had the same problem about a year ago, and it was fixed following this forum thread [1] where the issue was triggered by a new revision of the Pi hardware. Following that thread, I rand the i2c utility:
pi@raspberrypi:~/MIPI_Camera-master-3/RPI $ utils/camera_i2c
setting GPIO for board revsion: c03115
4B(1G/2G/4G/8G)
utils/camera_i2c: 204: utils/camera_i2c: utils/rpi3-gpiovirtbuf: Permission denied
Use i2c-10 for the sensor (-y 10)
This board revision (c03115) is not one I’ve seen before so it seems not unlikely that an update is required to the driver .so file.
Can you please confirm if the issue is that the driver requires an update, or if you think that is an unrelated issue, so that I may continue problem solving at my end in the later case, or request an updated driver in the former.
Many thanks
RD.
[1] init camera status = 4099 on IMX298 (16 MP) ArduCAM running on Pi 4B 8GB - #9 by planetprophet
