hello everyone. I am using Arducam V3Link Camera Solution Kit (TI) for raspberry Pi5. Help me for this. I faced broke pile
This board is tailored for TI SK-AM62A-LP/AM68A/AM69A development board, meaning it doesn’t work with the Raspberry Pi 5.
Here’s the board working with your Pi 5:
I want to implement it with rpi5 or rk3566. Do you have any suggest for me ? thank
I think it maybe working with 1 camera ? Am I right?
Hi @s2nmt
This V3Link Camera Solution Kit is designed specifically to work with the Raspberry Pi platform.
Thus, it won’t work on RK3566.
We reserve two camera ports on the serializer, meaning you can connect both cameras to it. However, you can only access one camera at once and swap the camera using I2C commands.
yes. I got it. But I need use Arducam V3Link Camera Solution Kit (TI) for Pi5 or RK3566. any suggest for me? . ex Modify driver or devicetree ?. I see pinout csi TI similar rpi5
You need to use this special V3Link Kit below with the Pi 5.
Your current V3Link Kit is only working with the TI board and is incompatible with the Pi 5.
If I want to use rockchip. Do you have any recommand board?
Hi @s2nmt
I would recommend this one:
It doesn’t require an additional driver and can work seamlessly on Rockchip.
