Hey all. I’ve been running a continuous live stream from an underwater camera setup for a while. The old setup was an Arducam v1 on a Raspberry Pi 4 (8GB) with the previous Raspbian, and I fed the stream straight into ffmpeg. I’ve just swapped to an Arducam v2 (12MP) and installed the new Raspbian Bullseye, and now raspivid won’t work at all — my whole ffmpeg pipeline is dead. I need to pipe the live stream from the v2 into ffmpeg like before. Has anyone hit this on Bullseye?
Welcome to the forum. To narrow this down, can you confirm the exact Arducam model and resolution, the Pi model and RAM, the OS version you’re on now, and the exact command/pipeline you used before the upgrade?
Sure. It’s the Arducam v2, 12MP, on a Raspberry Pi 4 with 8GB, running Raspbian OS Bullseye. The previous pipeline that worked with the v1 was:
raspivid -t 0 -w 1920 -h 1080 -fl -o - | ffmpeg -i pipe:0
That command is the clue. Raspberry Pi OS Bullseye replaced the legacy camera stack — raspivid and raspistill are gone — with libcamera-based tools. So on Bullseye, raspivid simply doesn’t exist anymore, which is why your ffmpeg pipeline broke.
The fix is to switch to libcamera and pipe libcamera-vid into ffmpeg the same way:
libcamera-vid -t 0 -o /dev/stdout | ffmpeg -i pipe:0
That keeps your live-streaming workflow intact.
Also worth checking the Arducam Native Camera Quick Start Guide for the libcamera setup steps: Quick Start Guide - Arducam Wiki — on Bullseye, libcamera replaces the legacy camera commands, so you output the video to /dev/stdout and pipe it into ffmpeg.
