Arducam UC-892 Rev C camera won't connect on Raspberry Pi 5 using Thonny IDE
Hi all, I’m trying to get my Arducam UC-892 Rev C working on a Raspberry Pi 5 but I can’t get it to connect to the camera at all. I’m using Thonny IDE and honestly I’ve never managed to get this thing to work since I bought it. Will the UC-892 Rev C even work with the Pi 5? Also, what libraries am I supposed to install for it?
Hi, yes the Arducam UC-892 Rev C can work with the Raspberry Pi 5, so let’s figure out what’s going on. Can you tell me which camera module you’re actually using with it?
I’m using the Raspberry Camera Module 3. I’ve tried a few things already but it still won’t connect. What libraries am I supposed to have for this setup?
Just to clarify, the UC-892 is essentially an extension cable kit, so there shouldn’t be any extra libraries needed to drive the camera modules. It’s compatible with the Raspberry Camera Module 3, and you’d just use the standard Raspberry Pi camera libraries (picamera2/libcamera). The cable kit itself doesn’t add any extra library requirements.
Okay, that makes sense. One more thing then - what’s the best cable to connect the Raspberry Pi 5 to the Arducam? The one I have, I’m having to twist it to get it into the Pi 5 connector and it really doesn’t feel right. Here’s a photo of the cable I’m using:
From your photo, you’re using a Raspberry Pi 22-pin to 15-pin MIPI cable, which should be compatible with the cable extension kit. For your use case, I’d recommend these cables:
If the cable you currently have works with the kit, you can keep using it. But if you’re having to force or twist it into the connector, one of the cables above is the safer bet. So to summarize where we are: the UC-892 Rev C does work with the Pi 5, it’s just an extension cable kit so no extra libraries are needed beyond the standard camera stack, and it’s compatible with the Raspberry Camera Module 3. The main thing to sort out right now is getting a cable that seats properly into the Pi 5.
