Hi, I am using an Arducam UC-852 with an OV9782 global-shutter sensor for a university project. Our main operating system is Ubuntu, but we also tested the camera on a Windows and experienced the same problem. The camera was working properly at first, but it has now suddenly stopped working and is not recognized when plugged in. We also replaced the built in adapter cable with another cable and tested different USB ports, but the issue remains.
Hi there,
You mentioned that the host won’t probe the camera at the moment. However, based on the screenshot you provided, it seems that the Ubuntu host can recognize the camera, but there’s something going wrong when streaming it.
Please help clarify so I can advise further.
we have 2 such cameras. currently only one is working. in the above screenshot, may be the other camera has appeared as connected. but still the faulty one gives>
And I have to say that, initially both cameras worked fine and we set 120fps and highest resolution and cameras worked. After like 15 minutes, we unpluged both.When we replug again one camera is not working… (not recognized by the PC)
May I send the signal that come from that cam to PC (using a USB protocol analyser) when we just plugin (for your investigations)?
