Dear Supporter,
I received the package for the device “Arducam UC-625 8MP Synchronized Stereo Camera Bundle Kit”.
I did setup the new device on the raspberry Pi 4B board follow the guideline:
https://arducam.com/downloads/modules/RaspberryPi_camera/Synchronized_Stereo_Camera_HAT_DS.pdf
All steps to install the device has been completed and verified.
However, I’m facing an issue for the Pi 4B can’t detect the camera (on Arducam Kit). Below are some my actions and result:
I run the command “pi@raspberrypi:~/MIPI_Camera/RPI $ ./list_format” and the result:
Hardware platform: c03112
init camera status = 4100 -
I run the next command “raspistill -t 0 -p 800,100,1024,768” and the result:
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component ‘vc.ril.camera’ (1:ENOMEM)
mmal: mmal_component_create_core: could not create component ‘vc.ril.camera’ (1)
mmal: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly -
I run the command “./camera_i2c” and the result:
setting GPIO for board revsion: c03112
Raspberry Pi3B / Pi3B+ / 3A / 4B(1G/2G/4G)
Set state of 133 to 1
00: – – – – – – – – – – – – –
20: – – – – 24 – – – – – – – – – – –
60: – – – – 64 – – – – – – – – – – –
70: – – – – – – – – -
Verify the setup once again: unplug the connected cables and reconnect again, using another cable (there 2 cables inside the package with same type) => Not Working
Verify that the camera is enabled on Pi 4B and follow steps to enable i2c_vc (https://github.com/ArduCAM/MIPI_Camera/tree/master/RPI)
Try to test with a Pi camera V2 (which is bought with Pi 4B), this camera is working normal. That presents that the camera port on Pi 4B is working normal. The root cause is maybe from the Arducam Bundle Kit.
Please support me to have any instruction to solve this issue.
