Thanks for the quick reply. I’m using SKU B0265R - the Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for Raspberry Pi (two 12.3MP IMX477 modules with CS lens and the Camarray Stereo Camera HAT).
When I tried to run the bug report tool it crashed:
./arducam-camera-bug-report
File “./arducam-camera-bug-report”, line 142, in
cmd_out = run_prog(args.c, args.t)
File “./arducam-camera-bug-report”, line 55, in run_prog
stderr=subprocess.STDOUT, errors=‘ignore’)
File “/usr/lib/python3.7/subprocess.py”, line 775, in init
restore_signals, start_new_session)
File “/usr/lib/python3.7/subprocess.py”, line 1522, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘libcamera-still’: ‘libcamera-still’
I also tried sudo apt install libcamera-still but apt reports there’s no package called libcamera-still. Has libcamera-still been renamed to rpicam?
Here’s the full Python code I’m running:
import arducam_mipicamera as arducam
import time
import os
import cv2
import numpy as np
import tkinter as tk
from tkinter import messagebox
def check_signal():
# region Variables Declared
global done_aligning
done_aligning = False
preview_name = "Preview Window"
projector_name = "Projector Window"
capture_base_path = '/home/pi/AllergyScannerPi/AllergySLS/Images/Intensity_Check/'
alignment_img = cv2.imread('/home/pi/AllergyScannerPi/AllergySLS/alignment/alignment_targets.png')
alignment_text = cv2.imread('/home/pi/AllergyScannerPi/AllergySLS/alignment/alignment_text.png')
GrayImgDir = '/home/pi/AllergyScannerPi/AllergySLS/gray_codes'
# endregion Variables Declared
def start_camera():
global camera
camera = 0
camera = arducam.mipi_camera()
camera.init_camera()
#fmt = camera.set_resolution(8112, 3040)
#print("Current resolution is {}".format(fmt))
try:
print("Enable Auto Exposure...")
#camera.software_auto_exposure(enable=True)
print("Enable Auto White Balance...")
#camera.software_auto_white_balance(enable=True)
except Exception as e:
print(e)
time.sleep(5)
def preview():
camera.start_preview(fullscreen=False, window=(100, 100, 800, 500))
def projector_window():
# projector resolution
projector_width = 1280
projector_height = 720
cv2.namedWindow(projector_name, cv2.WINDOW_NORMAL)
cv2.setWindowProperty(projector_name, cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_AUTOSIZE)
cv2.resizeWindow(projector_name, projector_width, projector_height)
cv2.moveWindow(projector_name, 1280, 0)
def preview_window():
cv2.namedWindow(preview_name, flags=cv2.WINDOW_GUI_NORMAL)
cv2.resizeWindow(preview_name, 300, 300)
cv2.moveWindow(preview_name, 900, 200)
cv2.setMouseCallback(preview_name, onMouse)
def get_gray_img(): # Create our list of stripes to be projected
# print('create_gray_list start')
gray_img = GrayImgDir + "/" + "441.png"
return gray_img
def alignment():
start_camera()
projector_window()
preview_window()
preview()
# show_alignment()
camera.stop_preview()
cv2.destroyAllWindows()
def project(gray_img):
# region load stripes into projector
img = cv2.imread(gray_img, 0) # read as grayscale
cv2.imshow(projector_name, img)
cv2.waitKey(1)
# endregion load stripes into projector
def capture():
# print('project_and_capture start')
#preview() # display in preview window on Pi
#projector_window()
filenameCamera = capture_base_path + "/" + 'Signal_Check.jpg'
save_capture(filenameCamera) # capture and write image
def save_capture(filenameCamera):
frame = camera.capture(encoding='jpeg')
frame.as_array.tofile(filenameCamera)
del frame # originally in terminate_camera
def terminate_camera():
global camera
camera.close_camera()
print("Close camera...")
def show_alignment():
while (True):
cv2.imshow(projector_name, alignment_img) # Display the preview and alignment images in their frames
cv2.imshow(preview_name, alignment_text) # clickable text to end alignment process with dialog
cv2.waitKey(1) & 0xFF
if done_aligning == True:
root = tk.Tk()
root.wm_withdraw()
root.geometry("1x1+1+1")
MsgBox = tk.messagebox.askyesnocancel('Alignment Process', 'Is the alignment complete?', icon='question')
if MsgBox == True:
done_aligning = True
root.destroy()
return
elif MsgBox == False:
root.destroy()
else:
exit()
def onMouse(event, x, y, flags, param):
if event == cv2.EVENT_LBUTTONDOWN:
def closing_dialog():
root = tk.Tk()
root.wm_withdraw()
root.geometry("1x1+200+200")
closing_message = 'The scanning process is complete, saved in Signal_Intensity'
MsgBox = tk.messagebox.showinfo('Complete', closing_message, icon='question')
print(MsgBox)
if MsgBox == 'ok':
root.destroy()
exit()
else:
exit()
def split_imgs(imagePath):
# read image
image = cv2.imread(imagePath)
height, width = image.shape[0:2]
# print('height, width dual line 50 ', height, width)
# Convert to grayscale
image = cv2.cvtColor(image, cv2.COLOR_BGR2GRAY)
# split image
croppedImageL = image[0:height, 0:int(width / 2)] # this line crops
croppedImageR = image[0:height, int(width / 2):width] # this line crops
print('Signals Seperated Successfully')
return croppedImageL, croppedImageR
# Call
start_camera()
preview()
projector_window()
gray_img = get_gray_img() # get structured light pattern
project(gray_img)
imagePath = '/home/pi/AllergyScannerPi/AllergySLS/Images/Intensity_Check/Signal_Check.jpg'
while True:
capture() # display stripes, capture images
imgL, imgR = split_imgs(imagePath)
imgL_mean = imgL.mean()
imgR_mean = imgR.mean()
print("The average of the Left sensor is " + str(imgL_mean),
"The average of the Right sensor is " + str(imgR_mean))
key = cv2.waitKey(1)
# ASCII Decimal codes: 27 is the esc key, 113 is the letter 'q', 10 is the Enter key
if key == 27 or key == 113 or key == 10:
break
time.sleep(0.2) # Rerun 5 times per second
#camera.stop_preview()
terminate_camera()
check_signal()
