sudo apt install python3-colcon-common-extensions
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
E: Unable to locate package python3-colcon-common-extensions
how to resolve it?
debian bullseye 11 64bit
Are you using a raspberry pi?
Only the jetson needs to be installed by itself, and the raspberry pi should be self-contained.
how to install sudo apt install python3-colcon-common-extensions by pairing arducam tof camera with raspberry pi without using jetson nano
Please explain me step by step software and hardware requirement to install ros2 and to install python3-colcon-common-extensions library , colcon build -merge install
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
This library should be included in the Raspberry Pi, do you have any errors about missing this library?
i trying to install this library python3-colcon-common-extensions
I getting Error:E: Unable to locate package python3-colcon-common-extensions
What is your output using the following command?
echo "source /opt/ros/humble/setup.bash" >> ~/.bashrc
source ~/.bashrc
colcon build --merge-install
/usr/bin/cmake: /opt/ros/humble/opt/libcurl_vendor/lib/libcurl.so.4: no version information available (required by /usr/bin/cmake)
gmake[2]: *** No rule to make target ‘/usr/lib/arm-linux-gnueabihf/libpython3.9.so’, needed by ‘tof_pointcloud’. Stop.
gmake[1]: *** [CMakeFiles/Makefile2:97: CMakeFiles/tof_pointcloud.dir/all] Error 2
gmake: *** [Makefile:160: all] Error 2
Failed <<< arducam [0.53s, exited with code 2]
Summary: 0 packages finished [1.17s]
1 package failed: arducam
1 package had stderr output: arducam
This error should have nothing to do with python3-colcon-common-extensions.
You can already use it library.
I checked your error, it seems that you did something else to cause the conflict.
Because I don’t know what happened in your system, you may need to solve this error yourself, something like
If you can’t solve this error, you can operate with a brand new system, do no other additional operations, just follow our documentation. See if the problem persists.
please explain steps to install ros2 and to collect point cloud
Release: 11
Codename: bullseye
There are many articles on our official website, you can refer to
https://docs.arducam.com/Raspberry-Pi-Camera/Tof-camera/Getting-Started/
