Arducam ToF and ROS2 installation issue
Hello. I’m trying to install ROS2 to my RaspberryPi 4B by this manual
https://docs.arducam.com/Raspberry-Pi-Camera/Tof-camera/ROS-With-Arducam-ToF-Camera/
At building stage i’m getting an error
pi@raspberrypi4b:~/Arducam_tof_camera/ros2_publisher $ colcon build --merge-install
Starting >>> arducam
— stderr: arducam
CMake Error at /opt/ros/humble/builtin_interfaces/share/builtin_interfaces/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package):
Could not find a configuration file for package “fastcdr” that is
compatible with requested version “”.
The following configuration files were considered but not accepted:
/opt/ros/humble/fastcdr/lib/cmake/fastcdr/fastcdr-config.cmake, version: 1.0.24 (32bit)
Call Stack (most recent call first):
/opt/ros/humble/builtin_interfaces/share/builtin_interfaces/cmake/builtin_interfacesConfig.cmake:41 (include)
/opt/ros/humble/rcl_interfaces/share/rcl_interfaces/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
/opt/ros/humble/rcl_interfaces/share/rcl_interfaces/cmake/rcl_interfacesConfig.cmake:41 (include)
/opt/ros/humble/rcl/share/rcl/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
/opt/ros/humble/rcl/share/rcl/cmake/rclConfig.cmake:41 (include)
/opt/ros/humble/libstatistics_collector/share/libstatistics_collector/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
/opt/ros/humble/libstatistics_collector/share/libstatistics_collector/cmake/libstatistics_collectorConfig.cmake:41 (include)
/opt/ros/humble/rclcpp/share/rclcpp/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
/opt/ros/humble/rclcpp/share/rclcpp/cmake/rclcppConfig.cmake:41 (include)
CMakeLists.txt:17 (find_package)
Failed <<< arducam [8.83s, exited with code 1]
Summary: 0 packages finished [10.2s]
1 package failed: arducam
1 package had stderr output: arducam
pi@raspberrypi4b:~/Arducam_tof_camera/ros2_publisher $ uname -m
aarch64
pi@raspberrypi4b:~/Arducam_tof_camera/ros2_publisher $ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
pi@raspberrypi4b:~/Arducam_tof_camera/ros2_publisher $ uname -a
Linux raspberrypi4b 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
How to resolve it?
sudo apt install python3-colcon-common-extensions
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
E: Unable to locate package python3-colcon-common-extensions
How to resolve it?
Release: 11
Codename: bullseye
You have to use the Raspberry Pi OS (32-bit) bullseye not the 64-bit version
What i did:
Install Raspberry Pi OS (32-bit) bullseye on SD-Card
sudo apt-get update
sudo apt-get upgrade
git clone GitHub - ArduCAM/Arducam_tof_camera
cd Arducam_tof_camera
./Install_dependencies.sh
When you see the reboot prompt, enter y. Raspberry Pi will automatically reboot.
curl -s https://raw.githubusercontent.com/v1ster/rpi-bullseye-ros2/main/install.bash | bash
echo “source /opt/ros/humble/setup.bash” >> ~/.bashrc
echo “export ROS_DOMAIN_ID=7” >> ~/.bashrc
source ~/.bashrc
cd Arducam_tof_camera/ros2_publisher
. install/setup.bash
ros2 run arducam tof_pointcloud
Rpi Zero 2W Raspberry Pi OS (32-bit) bullseye
sensor@tof:~/Arducam_tof_camera/ros2_publisher $ colcon build --merge-install
[Processing: arducam]
— stderr: arducam
/home/sensor/Arducam_tof_camera/ros2_publisher/src/arducam/src/tof_pointcloud.cpp: In member function ‘void TOFPublisher::generateSensorPointCloud()’:
/home/sensor/Arducam_tof_camera/ros2_publisher/src/arducam/src/tof_pointcloud.cpp:52:67: error: ‘CONFIDENCE_FRAME’ is not a member of ‘Arducam::FrameType’
52 | float *amplitude_ptr = (float *)frame->getData(FrameType::CONFIDENCE_FRAME);
gmake[2]: *** [CMakeFiles/tof_pointcloud.dir/build.make:82: CMakeFiles/tof_pointcloud.dir/src/tof_pointcloud.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:97: CMakeFiles/tof_pointcloud.dir/all] Error 2
gmake: *** [Makefile:160: all] Error 2
