RobotShop
Product Code: B0195S8MP
Raspberry Pi 4B
Online Documentation
Worked once in the beginning, then never again.
My RPi does not recognize my camera.
Using vcgencmd get_camera, I get the output of “supported=1 detected=0”
Using ./arducamstill in the MIPI_Camera/RPI folder, I get:
Open camera…
Hardware platform: d03114
init camera status = 4100
When I try raspistill -o Desktop/image.jpg, I get error messages:
Cannot read camera info, keeping the defaults for OV5647
mmal_vc_component_create: failed to create component ‘vc.ril.camera’ (1:ENOMEM)
mmal_component_create_core: could not create component 'vc.ril.camera (1)
Failed to create camera component
main: Failed to create camera component
Camera is not detected. Please check carefully the camera module is installed correctly
I have already ensured my connections are connected correctly and restarted and replugged my RPi and hat multiple times. I have already tried testing the hat with one and both cameras disconnected, and tested the wires given with a multimeter and verified they are conductive. I have also tried testing my RPi camera port by connecting an 8MP camera to it, where it does show an output.
How could I solve this problem of the RPi not recognizing the camera hat, or verify that I would need to request a replacement for the hat?
