Hey everyone, I just got the Arducam RGBD ToF Camera Kit (the T2 All-in-One model) and I’m a bit confused about the frame rate I’m seeing. The depth output seems to be hovering around 5 Hz — I’m getting roughly 5 fps consistently. Is this the expected performance for this camera, or is there a way to bump it up through some configuration? The spec sheet wasn’t super clear on this. I haven’t really changed any settings yet, just running it out of the box.
That ~5 Hz you’re seeing is actually below what the camera is capable of. It sounds like the camera is currently not running in its optimal mode — you should be able to get up to 7 fps out of it. Can you check which depth mode you’re currently using? The mode selection makes a difference in terms of the max frame rate you’ll get.
Thanks for the quick reply. To be honest I’m not sure which mode it’s in — I basically plugged it in and started grabbing frames without touching any mode-related parameters. Is there a specific mode I should be switching to? And I guess my bigger question is: is 7 fps really the ceiling here, or can it go higher than that with some tweaking?
You’ll want to switch the camera to near mode — that’s the configuration that lets you hit the maximum frame rate of 7 fps on the T2 All-in-One. The default mode you’re likely running in right now tops out around 5 fps, which lines up with what you’re observing.
And to answer your second question — yes, 7 fps is the hard ceiling for this hardware. There isn’t any configuration that will push it beyond that. The near mode is the recommended path to get there, but higher frame rates aren’t supported on this kit.
Got it, that clears things up. I’ll switch over to near mode and see how it goes. Bit of a bummer about the 7 fps cap, but at least I know I’m not leaving performance on the table now. Thanks for the help!
