Hi everyone, I’m stuck with my Arducam quadcam kit. It used to work fine on my Raspberry Pi 4B, but now the cameras just won’t work. Every time I try I get “camera frontend has timed out”.
My setup:
Raspberry Pi 4B
Bookworm OS 64-bit
8GB RAM
Arducam quadcam (quad-camera kit)
I’ve attached a bug report and some pictures of the wiring for reference. Nothing obvious changed on my end, but I’m not sure what to look for.
Thanks for the report and the photos. Since this worked before and suddenly stopped, did you change anything on the quadcam setup around when it started failing? New cable, different port, OS update, reseated the HAT, anything like that?
In the meantime, can you generate a fresh bug report so we can see the current state? Reboot the Pi, then run:
Right, I’ve also noticed the camera doesn’t work individually at all - it only ever worked when using it as part of the quadcam kit. I also tried moving everything over to a Raspberry Pi 5 and couldn’t get it to work there either. On the Pi 4B I installed the correct drivers, but on the Pi 5 it still won’t detect anything.
Quick question - does the “camera frontend has timed out” error only appear when you run the camera individually, or does it also happen with the full kit?
For the Pi 5 side: take the SD card from your Pi 4 (Bookworm OS, 6.6.20) and put it straight into the Pi 5. Also make sure the quad kit is connected to the CAM 1 port on the Pi 5’s board - that’s the port the default overlay expects.
Thanks, that matrix is really useful. Let me clear up a few hardware requirements, because some of those results are expected.
A single Arducam can’t be used on its own with either the Pi 4 or the Pi 5 - that’s not a supported configuration. You need at least two cameras assembled on the HAT board (RX0/RX1 and RX2/RX3). If there’s only one, the Pi won’t detect the kit or show a stream.
The overlay and port also have to match:
dtoverlay=arducam-64mp enables the CAM 1 port
dtoverlay=arducam-64mp,cam0 enables the CAM 0 port
So assemble all four cameras on the HAT board, connect the kit to the CAM 1 port, and use dtoverlay=arducam-64mp in config.txt. If you want CAM 0 instead, use dtoverlay=arducam-64mp,cam0.
Got it. So on the Pi 5 it’s still not detecting the HAT kit on either CAM port, even with dtoverlay=arducam64-mp,cam0. And on the Pi 4, detection works now with all four cameras, but the frontend still times out.
To confirm - this quadcam kit previously worked fine on the Pi 4, right? Did anything change in the setup around when the timeout started appearing? Any OS updates, cable swaps, or changes to config.txt?
Yes, the kit was working fine before. Then the frontend timeout error started showing up out of nowhere. I’ve tried several things since, but nothing has brought it back. Any suggestions or fixes for this? I’m still stuck with the timeout on the Pi 4 and no detection at all on the Pi 5.
Thanks for confirming. Let me summarize where we are so far:
Pi 4 with all four cameras: kit is detected, but “camera frontend has timed out” persists
Pi 5 with all four cameras: not detected on CAM 0 or CAM 1, even with the cam0 overlay
Single camera use isn’t supported on either Pi, so those failures are expected
Since the kit worked before on the Pi 4, the sudden frontend timeout is the key thing to chase down. If you can grab a fresh bug report from the Pi 4 with all four cameras connected and post it, we can look at what’s happening on the frontend side. We’re still investigating the sudden timeout, and I’ll follow up once we have something concrete to try next.
