Hey everyone. I’ve got a Pi Cam HQ (IMX477) that my Raspberry Pi 5 just won’t recognize. I want to use it for timelapse photography and video recording - a Pi Zero can’t really handle that workload, so the Pi 5 is what I’m trying to get it working on. Has anyone run into this before?
Welcome to the forum. Can you give us a bit more detail on your setup - which camera module exactly (is it the Arducam IMX477?), and what cables/adapters you’re using between the camera and the Pi 5? Also let us know what you’ve already tried so we don’t ask you to repeat the same steps.
It’s the Arducam Pi Cam HQ with the IMX477 sensor, running on a Raspberry Pi 5. I already went through this thread and tried everything listed in it: RPi5 Doesn't Recognize IMX477 - #7 by powerbroker - no luck. I’ve also swapped between a few different ribbon cables and tried flipping the cable orientation both ways. The weird part is the logs do mention IMX477, so it’s not completely invisible to the system. Here’s a screenshot of the logs, and I’ve attached a log file as well:
Thanks for the details. The IMX477 showing up in the logs suggests the overlay/driver is at least being loaded, but the camera still isn’t enumerating properly. Can you post photos of the physical connection at both ends - the Raspberry Pi side and the camera side? FPC connectors can look seated when they actually aren’t, especially on the Pi 5. We’d also like a bug report generated with our tool so we can look at the full picture. I’ll post the steps below.
Okay, I can take those photos. How do I run the bug report tool - is it something I need to download?
Yep. Here’s the full set of steps:
- Take pictures of the hardware connection at both the Raspberry Pi end and the camera end and post them here.
- Reboot your device.
- Download the bug report tool:
wget -O arducam-camera-bug-report https://github.com/Dion4cen/arducam-camera-bug-report/releases/download/Tool/arducam-camera-bug-report - Make it executable:
chmod +x ./arducam-camera-bug-report - Run it:
./arducam-camera-bug-report - That will output an
arducam-bug-report.txtfile in the current directory. Attach that file here so we can analyze it.
Done. Here are the photos of both ends of the connection. After rebooting I ran the tool and it generated the report - I’ve attached the arducam-bug-report.txt file. Let me know if you need anything else.
Got the photos and the report, thanks. We’re still going through everything. As it stands the root cause isn’t determined yet - the logs confirm the IMX477 driver is being referenced, but we need to work out why initialization isn’t completing. We’ll follow up here once we have findings. Hang tight.
