Hello everybody,
I am trying to use an Arducam OV9281 with a Raspberry 4B with Raspberry OS 32 bits
The arducam is: https://www.arducam.com/product/ov9281-mipi-1mp-monochrome-global-shutter-camera-module-m12-mount-lens-raspberry-pi/
I followed the steps here: https://www.arducam.com/docs/cameras-for-raspberry-pi/migrated/ov9281-1mp-global-shutter-raspberrypi-camera/
But apparently there is a problem with OV9281 at startup, see boot log:
4.850865] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.850902] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.850925] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.850945] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.852424] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.884897] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.896537] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.897499] usbcore: registered new interface driver brcmfmac
[ 4.919311] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.020061] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.020085] checking generic (3e7fe000 3fc000) vs hw (0 ffffffffffffffff)
[ 5.020106] fb0: switching to vc4drmfb from simple
[ 5.020775] Console: switching to colour dummy device 80x30
[ 5.021006] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.021020] [drm] No driver support for vblank timestamp query.
[ 5.021032] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.021639] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.060695] Console: switching to colour frame buffer device 170x48
[ 5.060742] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 5.164436] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.180631] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 5.633651] ov9281 10-0060: Unexpected sensor id(b45c1400), ret(-5)
[ 7.298060] random: crng init done
[ 7.298077] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.445940] uart-pl011 fe201000.serial: no DMA platform data
[ 7.608326] 8021q: 802.1Q VLAN Support v1.8
[ 7.881875] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.046273] Adding 2097148k swap on /var/swap. Priority:-2 extents:3 across:2457596k SSFS
[ 8.118602] bcmgenet: Skipping UMAC reset
[ 8.120198] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 8.120404] bcmgenet fd580000.ethernet eth0: Link is Down
[ 9.793677] broken atomic modeset userspace detected, disabling atomic
[ 12.312215] fuse: init (API version 7.31)
[ 12.316744] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 12.316772] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.134337] Bluetooth: Core ver 2.22
[ 14.134378] NET: Registered protocol family 31
[ 14.134384] Bluetooth: HCI device and connection manager initialized
[ 14.134398] Bluetooth: HCI socket layer initialized
[ 14.134406] Bluetooth: L2CAP socket layer initialized
[ 14.134421] Bluetooth: SCO socket layer initialized
[ 14.142894] Bluetooth: HCI UART driver ver 2.3
[ 14.142903] Bluetooth: HCI UART protocol H4 registered
[ 14.142960] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.146573] Bluetooth: HCI UART protocol Broadcom registered
[ 14.317987] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.317995] Bluetooth: BNEP filters: protocol multicast
[ 14.318008] Bluetooth: BNEP socket layer initialized
[ 14.320263] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[ 14.367427] Bluetooth: RFCOMM TTY layer initialized
[ 14.367445] Bluetooth: RFCOMM socket layer initialized
[ 14.367462] Bluetooth: RFCOMM ver 1.11
[ 31.836326] ov9281_dvdd: disabling
[ 31.836346] ov9281_dovdd: disabling
[ 31.836369] ov9281_avdd: disabling
Any advise please
Regards.
