Not sure. Company purchased it but likely UCTRONICS.
ArduCAM UC-580 Rev. C and ArduCAM UC-667 Rev. C adapter (programmed for OV9281 at purchase)
Xavier NX dev. kit programmed with JetPack 4.4.1 (downloaded 1/5/2021) straight from SDK Manager.
Automatic driver installation as per https://www.arducam.com/docs/camera-for-jetson-nano/mipi-camera-modules-for-jetson-nano/driver-installation/
On a Pi 4, but not the Xavier NX.
When I run the arducam_display.py example (https://github.com/ArduCAM/MIPI_Camera/tree/master/Jetson/Jetvariety/example) I get a black window. If I try to use V4L2 in C code I also get a black image. When I look at the dmesg log, it says that during boot, arducam-csi2 10-000c registered the sensor and subdev arducam-csi2 10-000c is bound to the tegra194-vi5 15c10000.vi hardware (firmware version 1, sensor ID 0x9281 reported). All looks good until I run the example, at which point it reports:
tegra194-vi5 15c10000.vi: no reply from camera processor
tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
These four lines then repeat until I stop the example.
I’ve tried to confirm the connections were properly made between the dev. kit and adapter board, and adapter board and camera. I tried a VC MIPI OV9281 camera (with its own Xavier NX image) and it worked so the MIPI connector works. I’ve also tried an IMX219 (before installing ArduCAM drivers) and that also worked.
I would like to get the camera working on the Xavier NX dev. kit.
Hi @dmadill ,
We are very sorry, but there have been some problems in our system recently, which caused us not to see your reply.
Not sure if your problem has been resolved, here is the response to the problem:
Will it work on the latest system? From the error message, it seems that the camera does not output data. This may be a cable problem.
Best Regards,
Hi @dmadil
how did you solve this problem? I am having the same issue as you described.
Ultimately we ended up using an OV9281 module connected directly to a CSI connector on our own daughterboard rather than the Arducam camera, and wrote our own driver. However, I believe we were also able to get the Arducam OV9281 camera working on a Pi connector on our daughterboard as well, but still using our own OV9281 driver and Xavier image. I don’t know if this would work on the dev. kit.
Is your daughterboard used, proprietory(custom-designed) or available in market? I’m also facing issues in integrating ArduCAM OV9281 module directly with CSI ports on Nvidia Orin nano at the present.
Our daughterboard is custom-designed I’m afraid. It’s part of a drone (QDrone 2 - Quanser). Just as a heads up with regards to the Orin Nano (as we also have experience with the Orin Nano and AGX Orin), we’ve noticed in general that the Orin-series seems to be a little stricter on the camera parameters in the device tree so check your max. pixel rate and other parameters carefully.
