The camera does seem to be detected. When I run dmesg | grep arducam I can see the camera and it prints the firmware version. But when I try libcamera-still or libcamera-hello, all I get is a blank window - no image at all.
If I run dmesg | grep arducam again while that libcamera window is open, I get this:
reading register 0x107 failed
What’s odd is that if I swap the SD card for a Buster install with the older drivers, the exact same camera setup works. So the hardware seems fine, it’s something about this OS/driver combo.
Things I’ve tried so far:
dmesg | grep arducam → detects camera, shows firmware version
libcamera-still and libcamera-hello → only opens a blank window
Swapped SD card to Buster OS with older drivers → camera works
Hi, thanks for the detailed report - the fact that it works on Buster but not Bullseye is actually the key clue here.
What’s happening: the B0267 was originally designed around the Buster system and uses the Arducam OBISP driver. That driver stack is what talks to the OV9281 sensors on this board. On Bullseye the camera stack is different (libcamera-based), and the B0267 isn’t compatible with it at present. The reading register 0x107 failed message you see while the libcamera window is open is a symptom of exactly that - libcamera is trying to talk to the sensor through a path that the B0267’s driver setup doesn’t support, so the register read fails and you end up with an empty/blank frame.
So to be clear on root cause: B0267 → Arducam OBISP driver → Buster only. Not Bullseye. Nothing wrong with your board or the camera itself, and your detection test confirms that (dmesg | grep arducam finding it with a firmware version is the expected good sign).
What to do:
Keep using the Buster system with the older drivers. That’s the supported configuration for this kit right now, and you’ve already confirmed it works there.
If you really need to run it on Bullseye, official support isn’t available, but you can reach out to Arducam’s sales team about a customization for Bullseye.
For now the practical answer is: stay on Buster for B0267. Let me know if you want to dig into anything else on the Buster side.
Thanks for the quick reply, that explains the blank window. I’m continuing to run on Buster for now since that works.
One thing though - I’m a bit confused because the product page for the B0267 links to documentation that shows the camera being used with the libcamera stack on Bullseye. That’s why I assumed it would work there.
Good follow-up questions, let me take them one by one.
Bullseye support - yes, Arducam is planning to launch a new version of the camera to adapt it to the Bullseye system. So official Bullseye support is on the roadmap, just not available on the current B0267 revision yet. Until that lands, Buster remains the supported path for this kit.
2x2 output - sorry, no. The 1x4 horizontally stitched output isn’t a config setting, it’s a limitation of how the program was written for this specific hardware. The original design only supports the 1x4 layout, so it can’t be switched to a 2x2 square.
Python scripts - there’s no ready example yet, the team is writing one. Once it’s finished you’ll get a Python OpenCV example for grabbing images from the B0267. I’ll make sure it gets passed along to you when it’s done (I’ll send it over in a private message when it’s ready so you don’t miss it).
So to summarize where things stand:
B0267 output is fixed at 1x4 horizontally stitched - 2x2 isn’t achievable due to the original hardware program.
Bullseye support is planned via a new camera version, not the current revision.
A Python OpenCV capture example is in progress and will follow.
In the meantime keep running on Buster with the older drivers, since that’s the supported configuration that works for you. Ping here if anything else comes up.
