Arducam OV9281 camera not detected on Jetson AGX Orin Jetpack 6.1 after driver install
Hi everyone. I’m trying to get an Arducam 1MP OV9281 Monochrome Global Shutter camera running on an NVIDIA Jetson AGX Orin Developer Kit with Jetpack 6.1. I followed the Jetvariety quick start guide and installed the driver with install_full.sh -m arducam, but after rebooting the camera isn’t detected at all. What’s confusing me is that my IMX219 sensor on the Arducam board works fine on this same Orin. I’ve also tried two different OV9281 Arducam modules and different cables, so I don’t think it’s a simple hardware/cable fault.
Environment:
What could be the problem, and what exactly is required to use this OV9281 on the AGX Orin?
Thanks for the detailed info. Can you paste the exact commands you ran for the Jetvariety install and the full output from the script? The output usually shows which kernel deb was picked for your board, and any warnings might point us in the right direction. After a reboot, also check whether any /dev/video* nodes show up.
Sure. I ran:
cd ~
chmod +x install_full.sh
./install_full.sh -m arducam
Full output:
./install_full.sh: line 19: warning: command substitution: ignored null byte in input
Downloaded arducam_links.txt [17705/17705]
Downloaded arducam-nvidia-l4t-kernel-t234-agx-orin-5.15.148-tegra-36.4.0-20241126114250_arm64.deb [10522992/10522992]
(Reading database … 211594 files and directories currently installed.)
Preparing to unpack arducam-nvidia-l4t-kernel-t234-agx-orin-5.15.148-tegra-36.4.0-20241126114250_arm64.deb …
Unpacking arducam-nvidia-l4t-kernel (5.15.148-tegra-36.4.0-20241126114250) over (5.15.148-tegra-36.4.0-20241126114250) …
ls: cannot access ‘nv_imx477.ko.bak’: No such file or directory
Setting up arducam-nvidia-l4t-kernel (5.15.148-tegra-36.4.0-20241126114250) …
ls: cannot access ‘nv_imx477.ko’: No such file or directory
mv: cannot stat ‘/boot/arducam/nv_imx477.ko’: No such file or directory
reboot now?(y/n):
The install log actually looks like the kernel package installed fine for the AGX Orin: arducam-nvidia-l4t-kernel-t234-agx-orin-5.15.148-tegra-36.4.0-20241126114250. The nv_imx477.ko.bak / nv_imx477.ko messages are about the IMX477 module and may not be relevant to the OV9281, but I want to see the state after reboot. Did you answer the reboot prompt? Please run:
ls /dev/video*
sudo apt-get install v4l-utils
v4l2-ctl --list-formats-ext
and paste the results.
Yes, I rebooted. Here’s what I get:
ubuntu@orin:~$ ls /dev/video*
ls: cannot access ‘/dev/video*’: No such file or directory
ubuntu@orin:~$ sudo apt-get install v4l-utils
v4l-utils is already the newest version (1.22.1-2build1).
0 upgraded, 0 newly installed, 0 to remove and 29 not upgraded.
ubuntu@orin:~$ v4l2-ctl --list-formats-ext
Cannot open device /dev/video0, exiting.
Thanks, that confirms the OV9281 isn’t being enumerated at all, even though the Jetvariety kernel package installed. Since your IMX219 works on the same Orin, the board/CSI side is probably okay. The next thing I need to confirm is the actual module you have. Can you post a clear picture of the OV9281 board? There are Raspberry Pi versions that look very similar but aren’t the same as the supported Jetvariety modules.
Here’s the IMX219 background, since it might help. On this same Jetpack 6.1 with kernel 5.15.148-tegra-36.4.0-20240912212859, the first install attempt gave: ‘Cannot find the corresponding deb package, please send the following information to [email protected]’, with that kernel version and ‘NVIDIA Jetson AGX Orin Developer Kit’. Support then gave me these commands and the IMX219 started working:
./install_full.sh -l
./install_full.sh -m imx219
For the OV9281 I used -m arducam as the Jetvariety guide says. I’ll attach the module photo in the next post.
Thanks. For the OV9281 you definitely need the Jetvariety driver (-m arducam), not -m imx219, so that part looks correct. The problem is that the driver installs but no /dev/video* nodes appear, so I need to verify the exact module type. Could you share the marking printed on the board (for example UC-788, Rev.B)? A photo would be ideal.
Sure. The module is an ArduCam OV9281 1MP Global Shutter camera with wide-angle M12 lens, MIPI, NoIR, monochrome. The board marking is UC-788, Rev.B. I’ve attached a photo of the exact module.
Thanks, that’s really helpful. Here’s where we are right now: the Jetvariety kernel package (arducam-nvidia-l4t-kernel-t234-agx-orin-5.15.148-tegra-36.4.0-20241126114250) installed successfully on your AGX Orin, but after reboot there are still no /dev/video* nodes, so v4l2-ctl can’t open /dev/video0. The install output also showed missing nv_imx477.ko / nv_imx477.ko.bak entries — those belong to the IMX477 module and may not affect OV9281, but it’s worth noting. I’m still verifying whether your UC-788 Rev.B module is one of the supported Jetvariety camera modules. Once that’s confirmed I’ll give you the next steps. For now, leave the driver installed and don’t reflash or change anything.
