Hi everyone. I’m running an Arducam OV5647 camera on a Raspberry Pi 4 and I just can’t get it to show up. I’ve been following the paper instructions that came with it and even reseated/reinstalled the camera a couple of times, but when I run libcamera-hello I always get “no cameras available”. It has never worked properly since I got it. Hoping someone can point me in the right direction.
That “no cameras available” error means libcamera isn’t detecting the camera at all, so we need to gather some system and camera config details. Please reboot your Pi first, then run the following to generate a diagnostic report:
That will produce a file called arducam-bug-report.txt in your current directory. Attach that txt file to your reply and I’ll take a look.
Alright, I followed those steps and downloaded the tool. Here’s the file you asked for.
I think there’s a bit of confusion here - you attached the downloaded script itself (arducam-camera-bug-report), not the report it generates. I don’t need the script. You actually have to execute it. So after downloading, make sure you run:
Once it finishes, it will write arducam-bug-report.txt in the current directory. Attach that txt file instead.
Sorry about that, my mistake. I ran the script for real this time and it generated the txt report. Attaching arducam-bug-report.txt now.
Thanks, I got the report this time. One thing I still need to pin down is which exact OV5647 module you have, because the setup path differs between variants. There are two possibilities: the standard OV5647 module, or the OV5647 with motorized focus. If you have the standard module, follow the official Raspberry Pi camera software guide here: https://www.raspberrypi.com/documentation/computers/camera_software.html. If it’s the motorized focus version, use this Arducam quick start guide instead: For 5MP OV5647 Motorized Focus Camera - Arducam Wiki. Can you check your module and let me know which variant it is? That will determine the correct configuration path from here.
