Hi everyone, I’m trying to get the Arducam OG02B10 Color Camera Module (2MP Global Shutter) working on a Raspberry Pi running Linux and I’m running into issues. I have this module specifically for evaluation of the OG02B10 sensor chip.
Can anyone tell me which Linux kernel driver supports the OG02B10 sensor? Specifically, is it directly supported by the arducam-pivariety.c driver? I’ve been digging around but can’t find a clear answer on what driver stack I should be targeting.
I know the page mentions Buster, but Buster is basically dead at this point — Raspberry Pi Foundation stopped supporting it. Is there any path to getting this running on Bullseye or Bookworm, or am I stuck?
Unfortunately, the OG02B10 module has been officially discontinued by Arducam, and its software and driver support was built specifically for the old Buster OS (Raspberry Pi OS). Since the Raspberry Pi Foundation no longer supports Buster, the module is effectively obsolete for any modern setup.
The core issue is that the driver stack and library support for that sensor were never ported forward to Bullseye or Bookworm. There’s no supported path to get it running reliably on a current Raspberry Pi OS version.
If you need a global shutter camera for evaluation on modern Pi setups, I’d recommend looking at the B0348 model — it’s the current replacement and is fully compatible with both Bullseye and Bookworm. That one will work out of the box on a modern system.
Thanks for the response, but I think I need to clarify — I’m not just looking for a drop-in replacement module. I’m specifically evaluating the OG02B10 sensor chip itself, so swapping to a B0348 isn’t really an option for my use case.
What I really need to know is: was there ever a kernel-level driver for the OG02B10? I keep seeing references to arducam-pivariety.c in various Arducam driver repos and I’m trying to figure out if that driver ever had support for this sensor baked in, even if it was only for the Buster-era kernel.
Even if it’s unsupported now, if someone can just confirm whether the driver existed and where the source lived, I can try to forward-port it myself or at least understand what I’m working with. Right now I’m just guessing.
That repo contains the driver library that was developed around the Buster OS timeframe. There’s a good chance the OG02B10-related sources — including any sensor-specific configuration and the driver glue — are in there. However, I need to be upfront: I can’t confirm whether arducam-pivariety.c specifically handles the OG02B10, because the official support window for that sensor closed when Buster went EOL and the module was discontinued.
In other words: the code may be in that repo, but nobody on our side is actively maintaining or validating it against modern kernels. You’d be on your own for forward-porting, and there’s no guarantee the sensor’s register maps or initialization sequences in those old sources are complete enough to work on a Bullseye or Bookworm kernel without significant rework.
If you go down that road, I’d suggest diffing against the newer Arducam drivers for currently-supported sensors — that might give you a template for what changed between the Buster-era and modern Pi kernels in terms of V4L2 subdevice APIs and media controller integration.
