Phoenix :
my camera having trouble opening. I’m able to call camera b at is i2c location but camera a isn’t receiving any data. The demo code also runs but can’t open the camera a file. I know camera attached to camera a works when not attached to the hat.
Arducam support team :
It seems that you need to enable the MIPI channel to receive data from Camera A as follows:
Phoenix :
The code I’ve been using matched what you’ve sent to me, but it still results in the same error.
Could you please connect your single camera to raspberry pi and test it?
Run this command "vcgencmd get_camera "
And then run “raspistill –t 0” to test if the camera and the cable are normal
Phoenix :
I’m able to run both camera through the raspberry pi and I’m also able to run both cameras through the camera B port.
Could you please test your single GPIO4pin ?
Our engineer think this pin wasn’t drove normally which made the port B cannot switch to port A.
Phoenix :
I’m able to make both GPIO pin 4 & 17 blink an led with a high/low changing.
