ArduCAM Mira220 RGB-IR camera not detected as video device on Ubuntu Jetson Orin Nano
Hi everyone, I’m trying to get an Arducam 2.2MP Mira220 RGB-IR Global Shutter USB3.0 camera (EK035 eval kit) working on Ubuntu. The setup is a Jetson Orin Nano running Ubuntu (Tegra), and this is going onboard a drone eventually. The problem is the camera gets detected as a USB device, but it never shows up as a video device. When I plug it in the light turns on orange/red, so it’s definitely getting power. I’ve tried loading it at 30 fps and 80 fps and it just won’t come up. Any ideas?
Thanks for the details. Can you check how it appears under lsusb and whether any /dev/video* nodes show up when it’s plugged in? The EK035/Mira220 has a config file requirement in some flows, so that’s worth ruling out early. I’ve sent you the EK035 configuration file through private message, please try it with that. Also, the quick start guide for the 2MP Mira220 USB3 kit is here: 2MP Mira220 USB3 Evaluation Kit - Arducam Wiki
There was also something about a Windows setup. I remember a config file was needed for that, and the driver wasn’t installed initially. On Windows I fixed the missing driver and the camera now shows up in the GUI. But on Ubuntu it still won’t appear as a video device. I followed the user guide and at first it failed to load on Windows too - I tried 30 and 80 fps. Also, even once it worked in the Windows GUI, the RGB color quality looked pretty bad and needs improvement.
Good, that’s useful. On Ubuntu, being seen as a USB device but not a video device usually points to the driver/config not being set up for the eval kit rather than dead hardware. Try loading with the config file I sent and the quick start guide steps, then check /dev/video* again. If it still fails, could you share a short video or picture showing the LED state and the exact error output? I’ve also brought one of our engineers into this to look at it.
I ran the script that support sent over and it couldn’t open the camera - same kind of behavior as the Windows software had when it failed. The LED is on but the device never comes up as a camera. I’m starting to wonder if this is a firmware issue. I’ll try the config file again on Ubuntu and see if anything changes.
Understood. If the script can’t open it even with the config file in place, and the Windows GUI also initially failed until the driver was fixed, then the Ubuntu side probably still has a driver/config gap. The key symptom is that it enumerates as USB but never becomes /dev/video*. We’re still checking with engineering on the firmware angle as well. Please send a clip of the exact error plus the LED state when you get a chance.
Quick update: even with the config file and following the quick start guide, Ubuntu still only sees the USB device - no video device at all. I tried loading at both 30 fps and 80 fps again. The light stays orange/red. I don’t get much in the way of logs, just the camera not being found.
To summarize where we are: the EK035 is enumerated as a USB device but not as a video device on Ubuntu (Tegra/Jetson Orin Nano). On Windows it now works after the missing driver was installed, so the hardware, LED, and USB path look okay. The remaining work is confirming the Ubuntu driver/config setup for the Mira220 RGB-IR USB3 kit using the EK035 config file, and our engineering team is still investigating the possible firmware/load issue at 30/80 fps. Root cause isn’t pinned down yet. If the config file plus the quick start guide still don’t bring up /dev/video*, please share a video of the error so engineering can dig in further.
