other
Mini-2MP-Plus
raspberry pi 4B/ Pico/ arduino Uno
video tutorial
never worked
Hi, please help me to run my arducam mini-2MP-Plus. I followed the video tutorials as below, my mini-2MP-Plus arducams just don’t work:
In the (1) video, I followed all the steps and tried lots of times. changed the pico, changed the arducam(I have three), changed the raspberry pi, checked all the wires and hardware, used the compiled uf2 file… after minicom -b 115200 -o -D /dev/ttyACM0, there is SPI bus fail…
so i tried to reach my arducam for just taking photo. I encountered the exactly same problem as other people(I put the link below). However, there are 3 cams and only one Uno… I can’t use the same solution.
please help me and thank you.
changed hardware, re-install software …
as possible as you can
I’ve successfully tested the ArduCAM 2MP on a Pico using the ArduCAM video Host on a MacOS, so this should be no problem.
One thing I notice is that the Host program you are running has the wrong Baud rate settings: try the 900K settings, since this matches the speed set in the client program that runs on the Pico.
To be precise, it’s the 921600.
The other thing to check is that the COM port is the correct one. You should see some strings coming from the Pico, while you just seem to see strings coming from the Host program itself.
I had to change the COM port to get the correct one.
Please don’t worry, I will try my best to solve the problem for you.
About SPI error,I suspect it is a wiring problem.
Please connect as shown in the figure below to ensure that the connection is normal.
Then use our test file to verify that there is no problem with the hardware. connection.Download test file RPI-Pico-CAM/tflmicro/bin/person_detection_Int8.uf2 file to Pico.
Open RPI-Pico-CAM/tflmicro/person_detection_display/person_detection_Display.pde displays the image,And check the port number.
I checked your connection and found no problem. You can try to use the Arduino UNO development board to drive the OV2640 camera to see if the camera is malfunctioning. If the camera is not malfunctioning, you can use a multimeter to check if there is any problem with the DuPont thread.
