test-sample as part of the Kickstarter Campaign -
MEGA-5MP
MEGA-5MP - Arducam Wiki -
ESP32 -
https://www.arducam.com/downloads/arducam_mega_getting_started_guide.pdf
ESP32 Node — SPICamera documentation -
I am directly controlling the camera by script and it works fine for all resolution modes except for the highest. Github–>CAM_IMAGE_MODE -
I have taken the provided sample code, which broadcasts the image file to a http endpoint and modified it, so that it stores the file on a local ftp server. this is my code, which works perfectly with all lower resolutions:
void sendImageData(String projectID = "default") {
String deviceID = String(EEPROM.read(0)) + "-" + String(EEPROM.read(1));
Serial.println("sending Image Data");
int i = 0;
char* filename;
unsigned long currentTime = millis();
char timestamp[50];
sprintf(timestamp, "%s_%s_%lu.jpg", deviceID.c_str(), projectID.c_str(), currentTime);
filename = timestamp;
Serial.println(filename);
// read bytes from camera and store in buffer
ftp.OpenConnection();
ftp.InitFile(COMMAND_XFER_TYPE_BINARY);
ftp.AppendFile(filename);
while (myCAM.getReceivedLength()) {
imageData = imageDataNext;
imageDataNext = myCAM.readByte();
if (headFlag == 1) {
buffer[i++] = imageDataNext;
if (i >= bufferSize) {
Serial.println("writing full buffer");
ftp.WriteData(buffer, sizeof(buffer));
i = 0;
// check for start of image data
if (imageData == 0xff && imageDataNext == 0xd8) {
Serial.println("start of image data detected");
headFlag = 1;
buffer[i++] = imageData;
// check for end of image data
if (imageData == 0xff && imageDataNext == 0xd9) {
headFlag = 0;
Serial.println("writing END Data");
i = 0;
break;
Serial.println("Image Sent");
ftp.CloseFile();
The uncommented line //Serial.print(imageDataNext) will show a constant stream of data. When working with lower resolutions, the serial output looks as expected:
writing full buffer
writing full buffer
writing full buffer
writing full buffer
writing END Data
Image send
the output starts immediately after calling sendImageData(),
Whereas on highest resolution there are two different behaviors, it does not start immediately and
(CASE 1) It does not set the headflag to 1 (does not get start of image) → the received image data is only one buffersize large and mostly empty
writing END Data
(CASE 2) It detects the start of the file multiple times
writing full buffer
writing full buffer
writing full buffer
writing full buffer
writing END Data
I have tried varying the buffersize too, without any effect.
- What help do you need?
I am not sure, what could cause this issue. Could you please point me in some direction, so that I can use the camera to its full potential.
Btw, the 3MP camera is working as expected!
