ArduCAM-M-2MP not working on Raspberry Pi Pico W (using Micropython)
    KSY Shop (https://raspberry-pi.ksyic.com/)
    ArduCAM-M-2MP OV2640
    Raspberry Pi Pico W
    I am trying to run the code ChatGPT 4o is suggesting.
    Here is the wiring.
ArduCAM Pin Pico W Pin Name Pico W Pin Number
VCC 5V (VBUS) Pin 40
GND GND Any GND Pin (e.g., Pin 38)
CS GP5 Pin 7
SCK GP10 Pin 14
MOSI GP11 Pin 15
MISO GP12 Pin 16
SDA GP14 Pin 19
SCL GP15 Pin 20
There are two Micropython files.
#arducam.py
import machine
import time
class ArduCAM:
    def __init__(self, spi, cs):
        self.spi = spi
        self.cs = cs
        self.cs.init(machine.Pin.OUT, value=1)
        self.init_camera()
    def init_camera(self):
        """ Initialize the ArduCAM-M-2MP module (OV2640) """
        self.write_reg(0x07, 0x80)  # Software reset
        time.sleep(0.1)
        self.write_reg(0x07, 0x00)  # Exit reset
        time.sleep(0.1)
        # βœ… Enable system clock and configure FIFO
        self.write_reg(0x03, 0x01)
        self.write_reg(0x45, 0x40)
        self.write_reg(0x10, 0x00)
        # βœ… Force OV2640 into JPEG Mode
        self.write_reg(0xFF, 0x01)  # Select register bank 1
        self.write_reg(0x12, 0x80)  # Reset sensor
        time.sleep(0.1)
        self.write_reg(0x12, 0x04)  # Set JPEG output mode
        self.write_reg(0xFF, 0x00)  # Select default bank
        # βœ… Enable FIFO Capture (Fixes issue where FIFO doesn't store data)
        self.write_reg(0x04, 0x00)  # Clear FIFO flag
        self.write_reg(0x04, 0x02)  # Start capture
        print("πŸ“· ArduCAM Initialized with 5V Power & Stabilized FIFO!")
    def write_reg(self, addr, value):
        """ Write to a register over SPI with proper CS handling """
        self.cs.value(0)
        time.sleep_us(10)
        self.spi.write(bytearray([0x80 | addr, value]))  # Write command
        time.sleep_us(10)
        self.cs.value(1)
        time.sleep_us(10)
    def read_reg(self, addr):
        """ Read a register value over SPI with proper CS handling """
        self.cs.value(0)
        time.sleep_us(10)
        self.spi.write(bytearray([addr & 0x7F]))
        result = self.spi.read(1)[0]
        time.sleep_us(10)
        self.cs.value(1)
        return result
    def flush_fifo(self):
        """ Clear FIFO buffer """
        self.write_reg(0x04, 0x01)
    def start_capture(self):
        """ Start capturing an image """
    def is_capture_done(self):
        """ Check if image capture is complete """
        return self.read_reg(0x41) & 0x08
    def read_fifo(self):
        """ Read image data from FIFO buffer """
        self.cs.value(0)
        self.spi.write(bytearray([0x3C]))  # FIFO read command
        img_data = bytearray()
        while True:
            byte = self.spi.read(1)[0]
            img_data.append(byte)
            if len(img_data) > 50000:  # Avoid infinite loop in case of error
                break
        self.cs.value(1)
        return img_data
Here is the contents of the second Micropython file.
#arducam_test.py
import machine
import time
import arducam
# βœ… **SPI1 Configuration (Optimized for Pico W)**
spi = machine.SPI(1, baudrate=1000000, polarity=0, phase=0,
                  sck=machine.Pin(10), mosi=machine.Pin(11), miso=machine.Pin(12))
cs = machine.Pin(5, machine.Pin.OUT)
#  βœ… **I2C1 Configuration (Optimized for Camera Sensor)**
i2c = machine.I2C(1, scl=machine.Pin(15), sda=machine.Pin(14))
#  βœ… Initialize ArduCAM with 5V Power
camera = arducam.ArduCAM(spi, cs)
def capture_image():
    print("πŸ”„ Flushing FIFO before capture...")
    camera.flush_fifo()
    time.sleep(0.1)
    camera.flush_fifo()  # Flush twice to ensure it's cleared
    print("πŸ“Έ Starting Image Capture...")
    camera.start_capture()
    time.sleep(2)  # Wait for image capture
    # πŸ” Check FIFO Status
    fifo_status = camera.read_reg(0x41)
    print(f"πŸ›  Capture Status Register (0x41): {fifo_status:#02x}")
    if fifo_status & 0x08:
        print("βœ… Image Captured Successfully!")
        # πŸ” Read FIFO Size
        fifo_size_high = camera.read_reg(0x42)
        fifo_size_low = camera.read_reg(0x43)
        fifo_size = (fifo_size_high << 8) | fifo_size_low
        print(f"πŸ“Š FIFO Data Size: {fifo_size} bytes")
        if fifo_size == 0:
            print("❌ Error: FIFO buffer is empty.")
            return
        img_data = camera.read_fifo()
        with open("image.jpg", "wb") as f:
            f.write(img_data)
        print(f"πŸ“· Image Saved! File size: {len(img_data)} bytes")
    else:
        print("❌ Error: Capture did not complete. Check power, SPI, and FIFO.")
# βœ… Run Image Capture Test
capture_image()
  1. Problems you were having?
    Camera doesn’t work. The result is something like this.
MPY: soft reboot
πŸ“· ArduCAM-M-2MP (OV2640) initialized!
πŸ›  Capture Status Register (0x41): 0x1
    None.
  2. Troubleshooting attempts you’ve made?
    Tried both 3.3V and 5V, different wiring. None worked.
  3. What help do you need?
    Any suggestions to identify the root cause.
