uctronics -
uc-923 for the camera - uc512-D1 for the hat -
Raspberry pi 4 4giga and 8 giga
A lot of try … raspi os 32 and 64bit old and last version -
All i have found nothing solve the problem, more than 15 try with different release -
No camera available -
dmesg
[ 0.000000] Linux version 5.15.84-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 28 pages/cpu s77336 r8192 d29160 u114688
[ 0.000000] pcpu-alloc: s77336 r8192 d29160 u114688 alloc=28*4096
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2015744
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:F7:BF:98 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=1d61b5bd-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] software IO TLB: mapped [mem 0x0000000034000000-0x0000000038000000] (64MB)
[ 0.000000] Memory: 7420676K/8192000K available (11520K kernel code, 1956K rwdata, 4136K rodata, 3776K init, 975K bss, 247036K reserved, 524288K cma-reserved)
[ 0.000000] ftrace: allocating 38065 entries in 149 pages
[ 0.000000] ftrace: allocated 149 pages with 4 groups
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 10)
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000360] Console: colour dummy device 80x25
[ 0.000422] printk: console [tty1] enabled
[ 0.000499] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000525] pid_max: default: 32768 minimum: 301
[ 0.000664] LSM: Security Framework initializing
[ 0.000965] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001098] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002427] cgroup: Disabling memory control group subsystem
[ 0.005512] rcu: Hierarchical SRCU implementation.
[ 0.006744] EFI services will not be available.
[ 0.007309] smp: Bringing up secondary CPUs …
[ 0.008544] Detected PIPT I-cache on CPU1
[ 0.008625] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.009833] Detected PIPT I-cache on CPU2
[ 0.009883] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.011082] Detected PIPT I-cache on CPU3
[ 0.011134] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.011287] smp: Brought up 1 node, 4 CPUs
[ 0.011309] SMP: Total of 4 processors activated.
[ 0.011323] CPU features: detected: 32-bit EL0 Support
[ 0.011334] CPU features: detected: 32-bit EL1 Support
[ 0.011346] CPU features: detected: CRC32 instructions
[ 0.044783] CPU: All CPU(s) started at EL2
[ 0.044863] alternatives: patching kernel code
[ 0.046804] devtmpfs: initialized
[ 0.058774] Enabled cp15_barrier support
[ 0.058815] Enabled setend support
[ 0.058844] KASLR enabled
[ 0.059043] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.059075] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.074786] pinctrl core: initialized pinctrl subsystem
[ 0.075638] DMI not present or invalid.
[ 0.076415] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.080285] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.080600] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.081525] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.081631] audit: initializing netlink subsys (disabled)
[ 0.081941] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[ 0.082540] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.082771] cpuidle: using governor menu
[ 0.083136] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.083336] ASID allocator initialised with 32768 entries
[ 0.083502] Serial: AMBA PL011 UART driver
[ 0.098058] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.128501] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-01-05T10:47:47, variant start_x
[ 0.132513] raspberrypi-firmware soc:firmware: Firmware hash is 8ba17717fbcedd4c3b6d4bce7e50c7af4155cba9
[ 0.185736] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.190189] vgaarb: loaded
[ 0.190652] SCSI subsystem initialized
[ 0.190872] usbcore: registered new interface driver usbfs
[ 0.190926] usbcore: registered new interface driver hub
[ 0.190995] usbcore: registered new device driver usb
[ 0.191423] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.191626] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.191930] pps_core: LinuxPPS API ver. 1 registered
[ 0.191943] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.191966] PTP clock support registered
[ 0.193631] clocksource: Switched to clocksource arch_sys_counter
[ 0.282233] VFS: Disk quotas dquot_6.6.0
[ 0.282345] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.282542] FS-Cache: Loaded
[ 0.282816] CacheFiles: Loaded
[ 0.284253] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[ 0.284274] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 0.284795] Console: switching to colour frame buffer device 240x67
[ 0.296377] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 0.306990] NET: Registered PF_INET protocol family
[ 0.308078] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.314194] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.314301] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.314333] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.314847] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.315970] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.316299] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.316457] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.316929] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.318591] RPC: Registered named UNIX socket transport module.
[ 0.318613] RPC: Registered udp transport module.
[ 0.318624] RPC: Registered tcp transport module.
[ 0.318634] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.318656] PCI: CLS 0 bytes, default 64
[ 0.321110] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.321462] kvm [1]: IPA Size Limit: 44 bits
[ 0.322739] kvm [1]: vgic interrupt IRQ9
[ 0.323020] kvm [1]: Hyp mode initialized successfully
[ 1.177034] Initialise system trusted keyrings
[ 1.177470] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.184588] zbud: loaded
[ 1.186498] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.187259] NFS: Registering the id_resolver key type
[ 1.187301] Key type id_resolver registered
[ 1.187312] Key type id_legacy registered
[ 1.187419] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.187433] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.188670] Key type asymmetric registered
[ 1.188686] Asymmetric key parser ‘x509’ registered
[ 1.188775] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.189036] io scheduler mq-deadline registered
[ 1.189051] io scheduler kyber registered
[ 1.197781] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.197834] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.197922] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.198004] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x01ffffffff → 0x0400000000
[ 1.263733] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.264143] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.264162] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.264180] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.264273] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.264525] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.268467] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.268831] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.268955] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.269382] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.273409] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.273457] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.273479] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.273519] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.273541] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.286694] iproc-rng200 fe104000.rng: hwrng registered
[ 1.287217] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.288738] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.301595] brd: module loaded
[ 1.311572] loop: module loaded
[ 1.312429] Loading iSCSI transport class v2.0-870.
[ 1.317935] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.381795] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.383017] usbcore: registered new interface driver r8152
[ 1.383101] usbcore: registered new interface driver lan78xx
[ 1.383157] usbcore: registered new interface driver smsc95xx
[ 1.432046] pci 0000:00:00.0: enabling device (0000 → 0002)
[ 1.432242] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.432279] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.433142] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[ 1.434222] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.434245] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.434284] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.434696] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.434718] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.434734] usb usb1: Product: xHCI Host Controller
[ 1.434747] usb usb1: Manufacturer: Linux 5.15.84-v8+ xhci-hcd
[ 1.434760] usb usb1: SerialNumber: 0000:01:00.0
[ 1.435523] hub 1-0:1.0: USB hub found
[ 1.435598] hub 1-0:1.0: 1 port detected
[ 1.436568] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.436591] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.436606] usb usb2: Product: xHCI Host Controller
[ 1.436620] usb usb2: Manufacturer: Linux 5.15.84-v8+ xhci-hcd
[ 1.436633] usb usb2: SerialNumber: 0000:01:00.0
[ 1.437278] hub 2-0:1.0: USB hub found
[ 1.437375] hub 2-0:1.0: 4 ports detected
[ 1.439269] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.439622] dwc_otg: FIQ enabled
[ 1.439633] dwc_otg: NAK holdoff enabled
[ 1.439643] dwc_otg: FIQ split-transaction FSM enabled
[ 1.439656] Module dwc_common_port init
[ 1.440290] usbcore: registered new interface driver uas
[ 1.440390] usbcore: registered new interface driver usb-storage
[ 1.440601] mousedev: PS/2 mouse device common for all mice
[ 1.446721] sdhci: Secure Digital Host Controller Interface driver
[ 1.446742] sdhci: Copyright(c) Pierre Ossman
[ 1.447434] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.451173] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.451813] hid: raw HID events driver (C) Jiri Kosina
[ 1.451979] usbcore: registered new interface driver usbhid
[ 1.451992] usbhid: USB HID core driver
[ 1.452352] ashmem: initialized
[ 1.461218] NET: Registered PF_PACKET protocol family
[ 1.461366] Key type dns_resolver registered
[ 1.462836] registered taskstats version 1
[ 1.462879] Loading compiled-in X.509 certificates
[ 1.463562] Key type .fscrypt registered
[ 1.463577] Key type fscrypt-provisioning registered
[ 1.475460] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.475766] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.475932] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
[ 1.485035] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.485527] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.486850] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.486871] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.516783] of_cfs_init
[ 1.516931] of_cfs_init: OK
[ 1.551635] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.552177] Waiting for root device PARTUUID=1d61b5bd-02…
[ 1.623141] mmc1: new high speed SDIO card at address 0001
[ 1.654746] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.655814] mmcblk0: mmc0:aaaa ACLCD 29.7 GiB
[ 1.660536] mmcblk0: p1 p2
[ 1.661129] mmcblk0: mmc0:aaaa ACLCD 29.7 GiB (quirks 0x00004000)
[ 1.674743] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.674865] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.675688] devtmpfs: mounted
[ 1.684036] Freeing unused kernel memory: 3776K
[ 1.684274] Run /sbin/init as init process
[ 1.684288] with arguments:
[ 1.684297] /sbin/init
[ 1.684307] splash
[ 1.684316] with environment:
[ 1.684325] HOME=/
[ 1.684334] TERM=linux
[ 1.689765] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.840372] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.840418] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.840436] usb 1-1: Product: USB2.0 Hub
[ 1.842612] hub 1-1:1.0: USB hub found
[ 1.842953] hub 1-1:1.0: 4 ports detected
[ 2.042349] systemd[1]: System time before build time, advancing clock.
[ 2.137736] usb 1-1.3: new low-speed USB device number 3 using xhci_hcd
[ 2.234744] NET: Registered PF_INET6 protocol family
[ 2.236781] Segment Routing with IPv6
[ 2.236827] In-situ OAM (IOAM) with IPv6
[ 2.246042] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c050, bcdDevice=27.20
[ 2.246078] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.246094] usb 1-1.3: Product: USB-PS/2 Optical Mouse
[ 2.246109] usb 1-1.3: Manufacturer: Logitech
[ 2.257135] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C050.0001/input/input0
[ 2.257684] hid-generic 0003:046D:C050.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:01:00.0-1.3/input0
[ 2.316046] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.317079] systemd[1]: Detected architecture arm64.
[ 2.321501] systemd[1]: Set hostname to .
[ 2.337703] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[ 2.448340] usb 1-1.4: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 1.04
[ 2.448385] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.448401] usb 1-1.4: Product: Dell USB Entry Keyboard
[ 2.448416] usb 1-1.4: Manufacturer: DELL
[ 2.463325] input: DELL Dell USB Entry Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:413C:2107.0002/input/input1
[ 2.526699] hid-generic 0003:413C:2107.0002: input,hidraw1: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:01:00.0-1.4/input0
[ 2.920405] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.068314] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.073144] systemd[1]: Created slice system-getty.slice.
[ 3.074608] systemd[1]: Created slice system-modprobe.slice.
[ 3.075601] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.076381] systemd[1]: Created slice User and Session Slice.
[ 3.076911] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.078156] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.078630] systemd[1]: Reached target Slices.
[ 3.078765] systemd[1]: Reached target Swap.
[ 3.079765] systemd[1]: Listening on Syslog Socket.
[ 3.080478] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.080860] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.082170] systemd[1]: Listening on Journal Audit Socket.
[ 3.082979] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.083907] systemd[1]: Listening on Journal Socket.
[ 3.091465] systemd[1]: Listening on udev Control Socket.
[ 3.092428] systemd[1]: Listening on udev Kernel Socket.
[ 3.093435] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.098047] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.102787] systemd[1]: Mounting RPC Pipe File System…
[ 3.108741] systemd[1]: Mounting Kernel Debug File System…
[ 3.114582] systemd[1]: Mounting Kernel Trace File System…
[ 3.115129] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.122775] systemd[1]: Starting Restore / save the current clock…
[ 3.128380] systemd[1]: Starting Set the console keyboard layout…
[ 3.134370] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.140451] systemd[1]: Starting Load Kernel Module configfs…
[ 3.147285] systemd[1]: Starting Load Kernel Module drm…
[ 3.153160] systemd[1]: Starting Load Kernel Module fuse…
[ 3.157793] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.164152] systemd[1]: Starting File System Check on Root Device…
[ 3.175971] systemd[1]: Starting Journal Service…
[ 3.193389] systemd[1]: Starting Load Kernel Modules…
[ 3.199639] systemd[1]: Starting Coldplug All udev Devices…
[ 3.213177] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.218348] systemd[1]: Mounted RPC Pipe File System.
[ 3.219413] systemd[1]: Mounted Kernel Debug File System.
[ 3.220414] systemd[1]: Mounted Kernel Trace File System.
[ 3.222934] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.226307] systemd[1]: [email protected]: Succeeded.
[ 3.227981] systemd[1]: Finished Load Kernel Module configfs.
[ 3.235099] systemd[1]: Mounting Kernel Configuration File System…
[ 3.288818] systemd[1]: Finished Restore / save the current clock.
[ 3.291116] i2c_dev: i2c /dev entries driver -
I have controled all connection with the four cameras and the hat to the pi4 all is new -
help to solve the problem why it’s not working
[ 3.291308] systemd[1]: Mounted Kernel Configuration File System.
[ 3.293528] fuse: init (API version 7.34)
[ 3.307958] systemd[1]: Started File System Check Daemon to report status.
[ 3.311472] systemd[1]: [email protected]: Succeeded.
[ 3.313136] systemd[1]: Finished Load Kernel Module fuse.
[ 3.316068] systemd[1]: Finished Load Kernel Modules.
[ 3.323523] systemd[1]: Mounting FUSE Control File System…
[ 3.329370] systemd[1]: Starting Apply Kernel Variables…
[ 3.367623] systemd[1]: Mounted FUSE Control File System.
[ 3.370826] systemd[1]: [email protected]: Succeeded.
[ 3.374766] systemd[1]: Finished Load Kernel Module drm.
[ 3.424117] systemd[1]: Finished Apply Kernel Variables.
[ 3.459046] systemd[1]: Finished File System Check on Root Device.
[ 3.464249] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 3.617408] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 3.624232] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 3.630920] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 3.631250] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 3.637013] systemd[1]: Starting Load/Save Random Seed…
[ 3.644654] systemd[1]: Starting Create System Users…
[ 3.646039] systemd[1]: Started Journal Service.
[ 3.725549] systemd-journald[140]: Received client request to flush runtime journal.
[ 3.739727] systemd-journald[140]: File /var/log/journal/b725bed85906490c82960e09f61334e1/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 4.807180] mc: Linux media interface: v0.10
[ 4.937694] videodev: Linux video capture interface: v2.00
[ 5.147500] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.148725] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.159299] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.165984] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.166032] [vc_sm_connected_init]: start
[ 5.178804] [vc_sm_connected_init]: installed successfully
[ 5.230146] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.231418] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.249291] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.268089] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.280914] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.281031] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.288122] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.302635] i2c i2c-22: Added multiplexed i2c bus 0
[ 5.305444] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[ 5.306325] i2c i2c-22: Added multiplexed i2c bus 10
[ 5.308088] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.317702] rpivid feb10000.codec: Device registered as /dev/video19
[ 5.327864] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.341589] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.343108] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.385753] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.386652] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.387310] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.401591] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.401708] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.401738] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.401760] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.401779] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.459984] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 5.460765] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 5.461406] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 5.474197] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 5.474280] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.474308] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.474329] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.474347] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.474789] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.493022] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.493095] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.500816] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.500905] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.558366] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.558443] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.568045] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 5.568132] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.637399] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 5.637466] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 5.643310] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.007374] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.038360] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 6.060415] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 6.618929] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.656548] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.789901] usbcore: registered new interface driver brcmfmac
[ 6.982362] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.991424] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 7.155053] checking generic (3e402000 7f8000) vs hw (0 ffffffffffffffff)
[ 7.155094] fb0: switching to vc4 from simple
[ 7.246337] Console: switching to colour dummy device 80x25
[ 7.291457] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.294372] Registered IR keymap rc-cec
[ 7.354009] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.478372] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
[ 7.752061] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.790090] Registered IR keymap rc-cec
[ 7.798093] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.798355] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input3
[ 7.869353] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.871809] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.872277] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.872650] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.872986] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.873277] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.881699] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.008822] dw9807_vcm: loading out-of-tree module taints kernel.
[ 8.022928] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 8.146207] dw9807 10-000c: I2C write CTL fail ret = -121
[ 8.191597] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[ 8.196511] Console: switching to colour frame buffer device 240x67
[ 8.196577] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 8.208752] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 8.208792] dw9807 10-000c: dw9807_standby I2C failure: -121
[ 8.212753] dw9807 10-000c: I2C write CTL fail ret = -121
[ 8.219783] arducam_64mp: probe of 10-001a failed with error -5
[ 8.633290] uart-pl011 fe201000.serial: no DMA platform data
[ 8.657543] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 9.088483] 8021q: 802.1Q VLAN Support v1.8
[ 9.603552] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.904335] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 9.905585] bcmgenet fd580000.ethernet eth0: Link is Down
[ 16.706548] Bluetooth: Core ver 2.22
[ 16.706755] NET: Registered PF_BLUETOOTH protocol family
[ 16.706763] Bluetooth: HCI device and connection manager initialized
[ 16.706783] Bluetooth: HCI socket layer initialized
[ 16.706793] Bluetooth: L2CAP socket layer initialized
[ 16.706822] Bluetooth: SCO socket layer initialized
[ 16.716806] Bluetooth: HCI UART driver ver 2.3
[ 16.716842] Bluetooth: HCI UART protocol H4 registered
[ 16.716999] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.717312] Bluetooth: HCI UART protocol Broadcom registered
[ 16.999007] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.999028] Bluetooth: BNEP filters: protocol multicast
[ 16.999043] Bluetooth: BNEP socket layer initialized
[ 17.022041] NET: Registered PF_ALG protocol family
[ 17.158445] Bluetooth: RFCOMM TTY layer initialized
[ 17.158483] Bluetooth: RFCOMM socket layer initialized
[ 17.158503] Bluetooth: RFCOMM ver 1.11
[ 31.709705] cam-dummy-reg: disabling
[ 45.446845] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 95.941034] v3d fec00000.v3d: MMU error from client L2T (0) at 0x8161000, pte invalid
cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
NAME=“Debian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=debian
at /proc/cpuinfo
processor : 0
BogoMIPS : 108.00
Features : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : d03115
Serial : 100000009a45bd6d
Model : Raspberry Pi 4 Model B Rev 1.5
ls /dev/video*
/dev/video10 /dev/video13 /dev/video16 /dev/video20 /dev/video23
/dev/video11 /dev/video14 /dev/video18 /dev/video21 /dev/video31
/dev/video12 /dev/video15 /dev/video19 /dev/video22
config.txt
dtparam=audio=on
start_x=1
camera_auto_detect=1
display_auto_detect=1
#Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
dtoverlay=arducam_64mp
dtparam=i2c_vc=on
dtparam=i2c_arm=on
gpu_mem=128
I see you post in many threads, we can just chat in this thread.
It looks like the camera is not connected properly, can you show me the connection diagram?
You can also try another flexible cable
Hello
I have already try other cable connection and i control all my plug
I exchange the cable from the hat to the pi by a camera cable … no changement .
How i can can be sure there no hardware problem, with the hat or cameras ?? ( i have already try on an other pi4 )
I try to power plug on by the hat and on the pi .
Thanks for your help
The green light will flash several times when the hat is first powered on. Can you describe the state of the light?
Another question, I found out that you use both gpio pins and typeC for power, you only need one.
No light on the hat and on the pi the green light blinking a lot a the boot moment .
For the power i use only the type C for the hat and the pi . GPIO are to plug the both together
This is not normal.
That slot is also for powering the hat. We have not tried a situation where both channels have power. This may corrupt the hardware.
I never plug two usb c, only one cable for the pi and the hat . No double power plug . but i can try with 2 usb c and i unplug gpio
I plug power cable on the pi and the hat on GPIO …
Maybe I made a mistake in my expression
The part I circled is all used for hat power supply
Only one of the two power ports needs to be connected.
on the picture it was the second solution … normaly i plug the power cable usb c on the pi4 … and the hat on GPIO but i never see light on the hat … only on the pi
When i receive the hat, my first test we plug the hat alone and no light was blinking at all that why my question … how can i control hardware problem , maybe it was a hardware problem from the beggining
I think like i see it , i can’t use this camera directly without the hat ?
Yes, these cameras are made for hats and have different firmware.
If the hat never lights up, then the hardware should be bad. You can contact sales for replacement ([email protected])
You can also write the link of this thread into the email, and I will tell them about your situation when they contact me.
Ok i contact them …
Thanks a lot
bye
If they don’t reply you for a long time, you can come and tell me.
I send to arducam and utronic (the shop where i buy ) maybe it’s the same but …
Thanks
