Hi, I’m trying to get an ArduCAM v3link IMX477 camera working on a Jetson Orin Nano with JetPack 36.4.0 (kernel 5.15.148-tegra-36.4.0). I ran the install_full.sh script from the driver package but it fails right away. The error I get is:
./install_full.sh: line 111: 5.15.148-tegra-36.4.0-20240912212859: syntax error: invalid arithmetic operator (error token is “.15.148-tegra-36.4.0-20240912212859”)
It says it can’t find a matching deb package for kernel 5.15.148-tegra-36.4.0-20240912212859. Does the script just not support 36.4.0 yet? Is there any way around this?
Right, install_full.sh doesn’t support JetPack 36.4.0 on the Orin Nano yet. That line 111 error is the script choking while trying to do arithmetic on the kernel version string — the format in 36.4.0 breaks the parsing.
There’s a newly built driver package for 36.4.0 (kernel 5.15.148-tegra-36.4.0-20241108101836). Download it on the Jetson and install with:
The officially supported JetPack versions are listed here: Introduction to Arducam Jetson Cameras - Arducam Wiki. If the new package gives you trouble, the other option is dropping back to a supported JetPack version.
Thanks, I grabbed the new deb and ran the dpkg install on my Orin Nano devkit (JetPack 36.4.0, kernel 5.15.148-tegra-36.4.0-20241108101836). The install seems to complete but I see this at the end:
Setting up arducam-nvidia-l4t-kernel (5.15.148-tegra-36.4.0-20241108101836) …
mv: cannot stat ‘/boot/arducam/arducam_csi2.ko’: No such file or directory
Is the install actually failing? The file it’s trying to move doesn’t exist.
That mv warning can be ignored — it’s not the cause of a camera detection problem and it doesn’t mean the package failed to install. Go ahead and restart the Jetson, then check whether the camera gets picked up:
ls /dev/video0
dmesg | grep imx
If /dev/video0 shows up and you see imx entries in dmesg, the camera is being detected by the system.
So after restarting, ls /dev/video0 shows nothing and the v3link imx477 still isn’t working. Weird thing is, I also have an ArduCAM IMX219 Quadrascopic camera that was working fine natively with no drivers needed. After I installed the imx477 v3link driver, the IMX219 stopped working too — basically no cameras at all. I re-flashed the Orin Nano and the IMX219 came back, so now I’m hesitant to reinstall the imx477 driver. Is there something else I need to do before installing the driver? And can the IMX219 Quadrascopic and the v3link imx477 even run at the same time, one on cam0 and one on cam1?
To be honest, the v3link IMX477 driver on 36.4.0 isn’t a reliable combo right now. The setup we’ve tested and documented uses JetPack 36.3.0. I’d recommend flashing the board to 36.3.0 and installing the drivers with the installation script instead of fighting 36.4.0. The supported platforms are listed here: Introduction - Arducam Wiki
Okay, so the installation script isn’t available for 36.4 yet, right? Any idea when the 36.4 script will be released? I’d rather not stay stuck on 36.3.0 forever if 36.4 support is coming.
I can’t give you an exact date, but the JetPack 36.4 installation script is in the works. Our target is roughly three weeks out. For now, 36.3.0 is the safe path if you need the v3link camera running reliably.
