Hi everyone, I’m building a WiFi access point camera streaming project using the Arducam IoTai ESP32 UNO PSRAM OV2640 Camera (B0192). I’m powering it from a 3.7V 18650 battery that goes through a switch and is wired to the onboard +/- connections. I’ve got two problems I can’t figure out.
When I plug in the micro USB cable, the board turns on automatically and starts running. I was expecting it to just charge the battery through the charge controller and stay off while charging. Instead it’s running and charging at the same time, which would basically mean it charges forever.
Is there any way to make the green ON LED light up when the battery is connected? When USB is plugged in the green LED comes on, but on battery power it doesn’t. I’d like the LED to indicate the board is actually on.
I already posted on a couple of forums and got no advice. Honestly I’ve never gotten this board to work properly. Does anyone know if either of these can be changed in firmware or hardware?
Thanks for the details. Before we go further, can you confirm whether these two behaviors actually affect your normal use, or are they just things you noticed along the way?
I checked with our hardware engineer about your situation. On the auto-power-on while charging, he said it’s out of the question — the board is designed to behave that way. And for the LED request, sorry, we can’t make it light the way you want either. Both points are limited by the hardware design, so they aren’t something that can be changed in software.
Yes, if possible it affects my use. Right now, with the micro USB plugged in, the board powers on while it’s also charging the battery, and that’s not the behavior I want for my camera setup. If there’s no way to fix this, I’ll have to scrap the project and look for another development board.
Sorry about that. Unfortunately, our hardware’s initial design can’t meet those requirements — the board staying off while charging over micro USB, and the ON LED lighting when powered from the battery. There’s no workaround or alternative we can offer for this. Sorry we couldn’t get you the behavior you needed.
